Trailer Safety Chain concern
/ Trailer Safety Chain concern #21
I wonder if you could fit a chain coupler throught the slot and connect the chain to it.
/ Trailer Safety Chain concern #22
</font><font color="blue" class="small">( if fact it's quite clever. )</font>
I was thinking that too. A very easy way to adjust the length of the chain, keep it from dragging on the ground.
/ Trailer Safety Chain concern #23
JJT,
I don't know about that. Won't each chain be taking half the weight? Plus, there may be more forces in effect which may add considerably more than just the tongue weight(dragging, whipping, bouncing, rolling, twisting and other technical things). How far upstate are you? The way I've got it figured, upstate is anything north of New York City, and northern New York is north of the thruway. So I guess I'm both.
/ Trailer Safety Chain concern #24
Maybe I'm missing something, but those slots don't look like you can pull the chain through them, so how do you adjust it? I think it looks rinky dink. Another technical term from northern New York.
Ok, I see what you mean by doubling over, so you can adjust. But I still don't like a pin that can fall out.
/ Trailer Safety Chain concern #25
TAWilson, agreed, each chain takes half the weight, but each chain has 2 ends, each getting half of the half. Upstate for me is 45 miles west of Albany, (Fonda/Fultonville area). JT
/ Trailer Safety Chain concern #26
Not all lynch pins are .10 cent specials. There are different grade lynch pins just like there are different grade drawbar pins and bolts and....
What I am getting at is that no one knows what quality or grade these lynch pins are. I have had them that the springs are so strong you have to work hard to open them and watch your fingers when you close them. Either way, I do like this setup on the trailer.
/ Trailer Safety Chain concern #27
</font><font color="blue" class="small">( TAWilson, agreed, each chain takes half the weight, but each chain has 2 ends, each getting half of the half. )</font>
This doesn't make since to me /forums/images/graemlins/confused.gif Just because there are 2 ends, doesn't mean that the weights gets split up. Lets see if I can explain my thought on this in a simple manner so that I can I understand it myself. Lets say we are going to pull a 10 lb. wooden block across the floor with a chain by the very end link. I exert 15 lbs. of pressure on the end of the chain to overcome the inertia of the 10 lb. block. The first link gets 15 lbs of pressure, so does the second link, the 3rd and so forth clear back to the link attached to the block. Am I correct in my thinking here? /forums/images/graemlins/tongue.gif
And as has been said by others because of whipping, bouncing, and swaying each chain will likely end up taking the entire load and actually more because of forces - not necessarily at the same time or for the whole duration of the event.
Back to the original question. I think it is pretty slick and probably wouldn't change it. A lot better than the way the manufacturer attached my chains on my little trailer. Both chains attached to a single bolt ran through the little triangle that forms the little leg for it to sit on when unhitched.
/ Trailer Safety Chain concern #28
I'll just chime in with a "looks fine to me, too".
I'de be more concerned with achieving a properly balanced load and tongue weight on a single axle trailer, but once you figure out the "sweet spot" and mark it, you would be ok.
Rip
/ Trailer Safety Chain concern #29
If it was a heavier trailer with two axles, then I would probable change it. But given the size and capacity of the trailer, I wouldn't be concerned.
BTW as said there are different strengths of lynch pins and you can also buy a locking lynch pin. With the locking one, you have to physically squeeze the bale together, before it will releases.
/ Trailer Safety Chain concern #30
How about doing this to keep everybody happy and have peice of mind. I'm sure you have enough chain to do this. Take the last link of the chain and bolt is somewhere on the trailer frame, come back a couple links and use the setup you have now with the lynchpins. This way you have both and nothing to worry about.
Michael
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
Ford 8340 (A53317)
Ford 8340 (A53317)
CFG Industrial MX15RX (A60463)
CFG Industrial...
2007 Kubota B21 TLB (A60462)
2007 Kubota B21...
2012 HEIL (A60736)
2012 HEIL (A60736)
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
