Dump Trailer Questions
/ Dump Trailer Questions #61
Sure trac 6x12 10k owner here. Mainly used for yard maintenance around my mini pine forest. I love it unconditionally, it's saved so much effort over last two years. I love it even more now that the price on them has gone up substantially(thanks Rona). Most I've done is three dump runs/day and battery was still 70%(dump is ten min from house). I stuck with the 10k so WaDot leaves me alone on the hiways. The dump is kinda like a tractor, once own one, you can't understand why you waited so long to get one.
/ Dump Trailer Questions #62
i have been a professional landscaper for over 20 years. downsized a few years ago. I used to own multiple 1 ton dumptrucks and 3/4tons with dumper inserts. we always pulled ramp trailers for the equipment. after downsizing I sold all the trucks and bought a dumptrailer, wish i had switched a long time ago. trucks break, engines/trannies/brakes wear out etc. have had zero problems with the dump trailer. I have a single direct mount lift cylinder and i can overload it. a scissor is almost always going to be outsized for the trailer. when I do overload (not often and i almost always know when i have)and it won't dump i use a hi lift jack. The first few inches of lift are the most difficult, once past that point it will lift anything. I have heavy ramps that store on the trailer and can easily haul any equipment i own. set up your truck with a good tekonsha brake controller and you can tow without barely noticing the trailer. I have since sold all my other trailers since the dumper can do it all. Mine has a spreader gate that also opens barn door style. It is a nice option but i rarely use it. usually i would rather dump a pile and use a machine to spread, that way i end up getting exactly what amount of material i want in the right place. BTW i can dump many times per day and never kill the battery, i do have a permanently mounted trickle charger on the trailer and plug it in most of the time it sits.
FYI. Some dump trailers have Gates only. No option to hinge open the bottom.
The trailer I am currently looking at (Doolittle 14') has 2 door versions "barn door" and "3 Way Spreader Gate" - The spreader gate seems to add about $1300 to the trailer price - The $1300 also adds "rub bars" not sure what that is yet :)
/ Dump Trailer Questions #65
You say "some dump trailers",does that mean I can still buy one with hinge open bottom belly dump? Are they available with gate plus bottom dump option or must you choose tailgate or open bottom?
/ Dump Trailer Questions #66
You can open mine from the bottom, open them in the middle like barn doors or open it from the top like a pickup. You’ll probably use the barn door function 90 percent of the time.
/ Dump Trailer Questions #67
Mine, too. I’ve used it like a pickup one time….
/ Dump Trailer Questions #68
I use my ton dump truck like that all the time because the load gets stuck under it if you try to bottom dump and it doesn’t have a barn door option. Another bonus is it protects the lights and keep the back of the truck clean. But it doesn’t work very good to dump a trailer like that because they’re too low to the ground.
I was hoping the "3 way" also opened like a truck tailgate.
I was about to ask that, thank you!
/ Dump Trailer Questions #70
The straight push cylinders on my sure trac are not big enough to lift the bed, so you have to either load tail heavy or carry the long arm jack to start the lift.--loader works too if you have one handy. I always have one of the skidloaders at the dump site. Quicker than messin with the jack! lol!
Also the cylinders are 2-way, another dumb idea! no wonder the new batteries only go for a couple loads. Gravity down would save on battery drain.
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
2022 John Deere R4023 (A60462)
2022 John Deere...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2007 Jeep Liberty 4x4 SUV (A59231)
2007 Jeep Liberty...
CFG Industrial H12R (A60463)
CFG Industrial...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
