Trailer Safety Chain concern
/ Trailer Safety Chain concern #21
I wonder if you could fit a chain coupler throught the slot and connect the chain to it.
/ Trailer Safety Chain concern #22
</font><font color="blue" class="small">( if fact it's quite clever. )</font>
I was thinking that too. A very easy way to adjust the length of the chain, keep it from dragging on the ground.
/ Trailer Safety Chain concern #23
JJT,
I don't know about that. Won't each chain be taking half the weight? Plus, there may be more forces in effect which may add considerably more than just the tongue weight(dragging, whipping, bouncing, rolling, twisting and other technical things). How far upstate are you? The way I've got it figured, upstate is anything north of New York City, and northern New York is north of the thruway. So I guess I'm both.
/ Trailer Safety Chain concern #24
Maybe I'm missing something, but those slots don't look like you can pull the chain through them, so how do you adjust it? I think it looks rinky dink. Another technical term from northern New York.
Ok, I see what you mean by doubling over, so you can adjust. But I still don't like a pin that can fall out.
/ Trailer Safety Chain concern #25
TAWilson, agreed, each chain takes half the weight, but each chain has 2 ends, each getting half of the half. Upstate for me is 45 miles west of Albany, (Fonda/Fultonville area). JT
/ Trailer Safety Chain concern #26
Not all lynch pins are .10 cent specials. There are different grade lynch pins just like there are different grade drawbar pins and bolts and....
What I am getting at is that no one knows what quality or grade these lynch pins are. I have had them that the springs are so strong you have to work hard to open them and watch your fingers when you close them. Either way, I do like this setup on the trailer.
/ Trailer Safety Chain concern #27
</font><font color="blue" class="small">( TAWilson, agreed, each chain takes half the weight, but each chain has 2 ends, each getting half of the half. )</font>
This doesn't make since to me /forums/images/graemlins/confused.gif Just because there are 2 ends, doesn't mean that the weights gets split up. Lets see if I can explain my thought on this in a simple manner so that I can I understand it myself. Lets say we are going to pull a 10 lb. wooden block across the floor with a chain by the very end link. I exert 15 lbs. of pressure on the end of the chain to overcome the inertia of the 10 lb. block. The first link gets 15 lbs of pressure, so does the second link, the 3rd and so forth clear back to the link attached to the block. Am I correct in my thinking here? /forums/images/graemlins/tongue.gif
And as has been said by others because of whipping, bouncing, and swaying each chain will likely end up taking the entire load and actually more because of forces - not necessarily at the same time or for the whole duration of the event.
Back to the original question. I think it is pretty slick and probably wouldn't change it. A lot better than the way the manufacturer attached my chains on my little trailer. Both chains attached to a single bolt ran through the little triangle that forms the little leg for it to sit on when unhitched.
/ Trailer Safety Chain concern #28
I'll just chime in with a "looks fine to me, too".
I'de be more concerned with achieving a properly balanced load and tongue weight on a single axle trailer, but once you figure out the "sweet spot" and mark it, you would be ok.
Rip
/ Trailer Safety Chain concern #29
If it was a heavier trailer with two axles, then I would probable change it. But given the size and capacity of the trailer, I wouldn't be concerned.
BTW as said there are different strengths of lynch pins and you can also buy a locking lynch pin. With the locking one, you have to physically squeeze the bale together, before it will releases.
/ Trailer Safety Chain concern #30
How about doing this to keep everybody happy and have peice of mind. I'm sure you have enough chain to do this. Take the last link of the chain and bolt is somewhere on the trailer frame, come back a couple links and use the setup you have now with the lynchpins. This way you have both and nothing to worry about.
Michael
/ Trailer Safety Chain concern #32
Ron, Not to worry. I'd leave it as it is or at most replace the pins with grade 5 bolts if the pin steel is in question. That configuration is better than many I've seen. Welding a piece of chain directly to the frame rails is not necessarily better, assuming your slotted bracket is of sufficient thickness and properly welded.
/ Trailer Safety Chain concern #33
</font><font color="blue" class="small">( Not all lynch pins are .10 cent specials. There are different grade lynch pins just like there are different grade drawbar pins and bolts and....
What I am getting at is that no one knows what quality or grade these lynch pins are. I have had them that the springs are so strong you have to work hard to open them and watch your fingers when you close them. Either way, I do like this setup on the trailer. )</font>
Exactly!!!
JerryG, you hit it also!! /forums/images/graemlins/laugh.gif
I can't figure out what all the fuss is about /forums/images/graemlins/confused.gif It's not like this is a "big" trailer.
RedDog
/ Trailer Safety Chain concern #34
To fail from pure pulling, the pin would have to sheer through or the plate around the slot would have to bend such that the pin could bend and pull through.
Even assuming the cheapest grades of steel involved, the geometries are such that the forces would need to be in the 10's of thousands of pounds. Probably higher than the chain itself is rated for.
I would be mostly worried about the spring-ring getting snagged on something or somehow bouncing loose. On tractor implements, lynch pins get lost all the time being dragged through brush and stuff. On the trailer, its probably less likely.
- Rick
/ Trailer Safety Chain concern #35
Think I would just pull one more chain link up on each side and slap a padlock on it. I’d still use the lynch pins but the lock would give me peace of mind and make sure someone else didn’t think they needed my chains more than me. As smart as we are here on TBN I’d bet the manufacture of the trailer has done enough figuring to feel safe enough from liability issues to continue to use the set up.
MarkV
2015 MACK CXU613 T/A 6X4 MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2015 MACK CXU613...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
2021 Dodge Charger AWD Sedan (A61574)
2021 Dodge Charger...
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
JOHN DEERE 1790 - 16R31" DRAWN VACCUM PLANTER (A63291)
JOHN DEERE 1790 -...
