Trailer plug receptacle recommendation
/ Trailer plug receptacle recommendation
Thanks guys.
I'll pick up some dielectric grease and let it works its magic.
Blane
/ Trailer plug receptacle recommendation #22
Thanks guys.
Blane
It prevents future issues generally, not fix existing ones. You'll need to clean any existing corrosion off or replace connectors first.
/ Trailer plug receptacle recommendation #24
Also check for corrosion INSIDE the plug. I had a plug which worked most of the time. On disassembly it was corroded inside and must have made contact occasionally.
/ Trailer plug receptacle recommendation #25
For cleaning inside the plugs I've used dental picks to scrape, folded emory cloth to scrub, and rifle cleaning brushes especially for round terminals.
/ Trailer plug receptacle recommendation #26
All the posters have great advice. Over the decades, I have dismantled perfectly working plugs and recepticles and done an **** maintenance on them BEFORE they give me a problem. I have encountered frays and rogue pieces of wire, along with corrosion in its' infancy. Just figure it is a given that your stuff is gonna go haywire sometime. A lot has to do with your locale., In Western Oregon, rust never sleeps, although it shacks up with corrosion.
/ Trailer plug receptacle recommendation #27
Many plugs corrode internally - under the plastic / rubber, you won't see it until you cut it open - with all the towing you do I would do a couple of things, I'd get a trailer wire maintenance kit - it comes with pin cleaners, wire brush, files, grease, cotton swabs and instructions, a few companies make them - some better quality than others but at least you'll have the proper tools to do the job, each piece can be replaced with better quality if / when needed - I'd also replace the harness with an all-weather one, the all weather are blue, not only are they sealed better they don't stiffen in cold weather a major plus for snow users!! You also want to make sure the trailer battery is in good shape - the battery can cause issues with the system, even when you thing the truck power is taking over. A simple trailer plug tester will let you know if your getting the proper power to the trailer another nice item to have - sounds like a lot but like worth not having to test the pucker power....
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2018 Colombo Twin Master (A64119)
2018 Colombo Twin...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
