trail clearing technique and tools
/ trail clearing technique and tools
The tools along while blazing.
And the help.
/ trail clearing technique and tools #943
Try wrapping your hand/wrist when using the brush cutter.
And, wear a wrist brace at night. I too will wake at night from carpel tunnel pains in my hands but sleeping with a simple loose "wrist brace" is all it takes to get through the night.
I've found that the combination of land work (amateur/hobbyist) and computer work (professional) can wreak havoc on the hands and wrists.
Don't forget the muscles that open/unclench your fingers and the ones that pull the wrist back away from the grip - usually when I have wrist pain I can do some light wrist reverse curls, with a small dumbell or other weight, and this helps the wrist greatly.
Even if you look like those muscles are heavy duty on your arm, you can probably use a bit more concentrated strength there to balance - if when you stand with your arms relaxed at your sides, if your wrists automatically curl in a bit you're probably out of balance.
Basically put your arm, palm down, across a bench or counter so that the forearm is supported; grasp a weight in the hand, gently lower your wrist down with gravity, pull back up - only flexing the wrist. Repeat. Make sure you use a light weight, I'm serious, most of us other don't use these muscles much.
The fellow with the wrist grief has not responded since.
While on a hike over the 4th, in northern MN, we passed a power line grade that had been freshly brushed. All I ever seen doing this job is a skidsteer with a carbide toothed spinning thing. What are they called? I'd like to know how they miss the rocks!
Today I picked up a kubota tractor owned by a good Samaritan who likes our trails. With it today I smoothed out some lumps of dirt left by a logging company to improve drainage for our parking lot and snow removal. Plus I knocked out some old stumps I hit while plowing. On Saturday i will be mowing with it.
/ trail clearing technique and tools #948
Pretty trusting of a guy to lend his cabbed tractor for work in the woods.
/ trail clearing technique and tools #949
Arly, I believe they are called forestry mulchers. They are quite the machines and are expensive. I know they also take a lot of hydraulic flow to run them to. I suspect they start out with the head held high and work their way lower with it to avoid rocks but I’m not sure. Like everything I suspect they get skilled.
Looks like your solidly in the tractor shopping mode after borrowing that bad boy. :) Nice of him to lend it to you.
Got the trails mowed today. Took about 5 hours with this 72" cut machine. Grass, shoots and weeds not all that thick this years due to lack of rain. Did see some 4ft tall ferns along the way. This tractor did have ac but prefer not have the cab for ground visibility sake.
All done.
/ trail clearing technique and tools #952
Much better/easier than using a string trimmer. Looks great.
/ trail clearing technique and tools #955
Was doing an HOA cutting last week with the F-3680. Just unloading here
Noticed rapid overgrowth of walking trail. I have to get this crap cut back on this walking trail we mow. They want a bid. About 1/2 mile of trail. Thought of possibly using the Stihl Kombi and the “hedge clipper” attachment. Mostly multi-flora, vines. Light stuff.
/ trail clearing technique and tools #956
Am told they are terribly expensive to insure for liability.
/ trail clearing technique and tools #957
They do a great job under the power lines though.
/ trail clearing technique and tools #958
I just bought a flail with hammer cutters for my bigger excavator. Can't wait for it to show up.
With the back-blade on the loaner kubota* I smoothed up dirt lumps more today after speaking with a snow plow guy. Then a trail walk. Lots of people out there today but no pics of them. I may be an amateur but I was proud of the the smoothness I achieved.
*I do not like the single forward-reverse peddle in these machines.
/ trail clearing technique and tools #960
Nice work!
The Kubota Treadle is definitely a "Goofy Foot"
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
LiuGong 9027FZTS Mini Excavator (A64553)
LiuGong 9027FZTS...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
462001SFL (A64557)
462001SFL (A64557)
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
