Tractor Tie Downs
/ Tractor Tie Downs #41
I’m saying that every commercial vehicle inspector across the land enforces 49 CFR for load securement, I do not know of NYS having load securement laws, we adopted the 49 CFR regs for that.
Think about how much sense this makes......
if I have a track mini excavator do I not need tie downs? There are no tires?
If I have dual wheels in the back of my tractor, do I need 6 tie downs?
If I have one of those utv land water buggy’s do I need 6 tie downs? The ones with 3 tires on each side.
If I take off the two front tires and block up the front end, do I now only need one tie down?
It makes no sense to demand number of tie downs per tire, it’s way to broad of a regulation.
/ Tractor Tie Downs #42
I had my trailer in front of the hardware store couple years ago, and John from John's towing came out and said you better put two more chains on that tractor and straps on your loader backhoe, unless I like paying fines to Washington, county, have a to go up to Ft Edward tomorrow and check on pistol permit, will check on county and state laws for towing. I wasn't trying to comment on federal regulations.
Problem with John from Johns towing is he is held to the standards of 49 CFR as he is in business.
If your dealing with the local sheriff or PD, I guess they could make up something like your saying, I mean they could say you can’t drink Pepsi after 9pm on Friday in the street either.
/ Tractor Tie Downs #43
I don't quite understand why you brought up Federal regs in this instance, I'm not hauling over the road, tractor is 3500lbs on a 14,000 lb trailer. I'm up and down the Thruway from Ontario to Boston and have yet to see any car carrier only have two straps on any car and in any position on the racks. At most, I travel 30 miles down to Troy and back one or twice a year. If your correct, so be it, I stand corrected then, but, I don't chain down to the requirement, I go way past the requirement for my own personal satisfaction.
/ Tractor Tie Downs #44
And you can put 100 tie downs on something, I just don’t want people thinking they have to do things that aren’t required.
Oh and you can’t bring cars into this, they have a whole different section for how they are secured.
/ Tractor Tie Downs #45
I understand what you are saying, my example would only apply to tractors, or 4 wheelers, but you are responding with it's wrong, I can accept that. If I drive up towards Plattsburgh on 87 and your in Twin Peaks and you see I over secured my tractor and equipment I doubt you or your comrades would ticket me. Well, in the early 1980s I got an overweight ticket in Peru on my way down to Lake George with a load of bark mulch coming down from Faccets Quebec up by Hawksbury but that was many moons ago. That was back when I had grey hair and New York upstate was alot of fun, less regulations and more work than we could handle.
/ Tractor Tie Downs #46
Let me let you go, I'll get a couple of hours sleep then get the backsplash grouted, have a good day and thanks for straightening me out with this info.
/ Tractor Tie Downs #47
I used to haul heavy equipment over size all over the lower 48 true each state has there own required amount of chains on each piece of equipment. But I have been told you can use straps to hold a bucket on loader and one a backhoe. But I have found over the years hauling the loads just do it the way the most restricted state requires and you will be good in the other states to me Alabama was the worst state for required tiedowns. This is the required for a 40 ton excavator not that y'all be hauling that but just giving you what a big truck oversize needs to learn and go by I have been thru the scales in every state most of the time if they see that you have the minimum requirement they won't bother you I have even measure the tracks to make sure it was on straight. You need 2 chains on each track cross chained front and rear also 2 from the frame of the machine to the trailer front and rear and then either a strap or I used a chain over the bucket to prevent it from swinging that's a minimum of 9 chains per. And of course the heavier you get the more is required so just make sure use whatever makes you feel comfortable if it's chains or straps make sure that they are rated for what you are securing.
/ Tractor Tie Downs #48
Each wheel is supposed to be chained or strapped, so 4 tires 4 chains or straps, up in Washington county it used to be $100 fine for each wheel NOT chained or strapped could be more now in 2018
In addition, to the wheels, the loader and backhoe must be fixed to the trailer, I just ran straps over both and tied down. I live in a small town, and doesn't take much to be remembered from the Sheriff's Dept, so I try and be as legal as I can be.
I am going to go with "not so much" (unless you had a tractor that weighed over 10,000# on the trailer). Here is what NYS has to say:
https://www.dot.ny.gov/divisions/operating/osss/truck/regulations said:
Commercial Vehicle Safety Regulations
USDOT-How to Comply Manual
In general, New York State has adopted the Federal Motor Carrier Safety Regulations found in Title 49 of the Code of Federal Regulations (49 CFR), Parts 390, 391, 392, 393, 395, 396, and 397 and the Hazardous Materials Transportation Regulations found in 49 CFR, Parts 100 through 199 as they apply to interstate highway transportation.
There are specific exceptions to some of these regulations for vehicles operated strictly within New York State. Some of those exceptions are discussed in the following pages. Refer to Title 17 of the New York Codes, Rules and Regulations (NYCRR) Part 820 for specific requirements.
The federal regulations can be viewed at the Federal Motor Carrier Safety Administration Web site
The New York State Transportation Law (TRA Section 140), Environmental Conservation Law (ENV), and the Vehicle and Traffic Law (VAT) can be viewed at the New York State Legislature Website
Household Goods
The New York State Transportation Law (TRA Sections 190 through 199) and Title 17 of the New York State Code of Rules and Regulations Part 814 govern the transportation of household goods within New York State.
So, if your tractor weighs under 10k, you only need 2 tiedowns for the tractor (plus one for the backhoe and another for the loader). Is it a good idea to use 4 straps/chains? Yes, but it's not required.
As for the car carrier, there are a couple of things in play:
1. If they chain to the frame, the slots in the unibody "frame" are only rated for so much weight (think big bumps in the road for shock loading).
2. If the car moves and hits another car or is otherwise damaged, they (or their insurance company) have to pay for repairs.
So, they have a significant incentive to make sure the cars don't move at all.
I agree on oversecuring, when our BX2660 goes on the trailer, it gets 4 2" 3333# WLL ratchet straps...
Aaron Z
/ Tractor Tie Downs #49
I bought 2 of the keeper brand straps linked above and so far not superior impressed. It’s a good strap and it has the WILL printed on the side, but it’s about the same quality as my tractor supply strap that cost half as much. While I was at it I bought another lawn mower tie down system. Since it came with 2 pretty good 2” straps I feel like the valve is pretty good for about $35. IMG_4534.JPGIMG_4535.JPG
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2014 Parker Trailer Sales Trailer (A60352)
2014 Parker...
Sakai SW354 (A60462)
