crashz
Elite Member
With the new trailer and newly formed side business, I have been moving my Kubota nearly every weekend. Each project typically has been mowing, and mostly with the brush cutter. The new trailer is an 18ft equipment hauler and I use every inch of it with the Kubota with cutter and loader.
What I have done, both for convenience and tagging (the straps have load tags from the manufacture) is gone to heavy duty load ratchet straps. I normally keep them in each truck anyway, and each are rated at 3,330 lbs working and 10,000 breaking strength. To tie down the machine, I use three large straps, two in the front (one on each side) hooked to the tie down loops on the trailer and then hooked to the front frame where the grill guard attaches. The third is looped through a clevis on the draw bar and to each tie down loop in the back. The loader and cutter are then strapped down with the small ratchet straps rated for 500 lbs each.
The straps are easy to store, lighter and a lot cleaner. They also seem to stay tighter, as I never have to re-tighten them and are always still tight once I'm at my destination.
But I've always been a chain guy. And while a 5/16" chain may have the same working load limit, it just feels stronger. And so it just feels wrong.
I know this has been hashed out a lot before, but I think its a relevant topic to keep at the top of the list and I'd really like the groups opinion.
