Tractor supply and imatch
   / Tractor supply and imatch #1
Machinewars
Chapel hill, nc
CX2510
Anyone know if the TS carryall is imatch compatible? If so anything to look out for when building the carryall.
   / Tractor supply and imatch #2
I have a TSC carry all that I bought last year. It is the Countyline brand and is quick hitch compatible but is not imatch compatible. There is no upper hole for the top link hook connection nor is there room for it. There are no holes below the standard lower link pins either so you can't lower those either unless you drill them out yourself. I don't know if that will work for your tractor.
You have to be careful with TSC, as what they show online and in their catalog is not necessarily what they actually have in the stores. I wanted to get the cat 1 middle buster which is shown online and in their catalog as being quick hitch compatible. The one carried by all of my local stores was not.
Anything I buy will be quick hitch compatible if it is made by some company, somewhere. I'm getting too old to fool around with connecting 3 point attachments if I can easily use a quick hitch.
paulemar,
Thank you for the help.
Are you sure on this? The carryall I saw yesterday did have the hole for the top link. A pin was not included but the hole was there.
   / Tractor supply and imatch #4
paulemar,
Hmmmmmm, I'm a bit confused about the imatch. Of course the carryall does have a hole for the toplink or quick hitch hook, but I thought that the imatch quick hitch was built so that it fit John Deere implements but other brands not so much. I tried looking it up and couldn't find out the difference between a standard quick hitch and an imatch. I've looked at implements that claim to be compatible with both and they seem to have 2 holes for the imatch/quick hitch hook. I have the Cheap harbor freight quick hitch and had to initially do a little grinding, but both quick hitch compatible implements I have, including the carryall, fit just fine.
You can always measure your imatch and then the carryall to make sure that it will fit before you buy.
   / Tractor supply and imatch #5
Anything thats listed as quick hitch compatible should be ok with deeres imatch. I have converted all of my older stuff to imatch specs. If you google imatch and quick hitch specs all the dimensions are online.
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
