Tracks for chinese dozer.
/ Tracks for chinese dozer. #1
bobgebroski
USA WV.
Yct306-3
Would anyone happen to know the correct size rubber tracks to fit on Yuchai / East Wind yct306 dozer. Thanks.
/ Tracks for chinese dozer. #2
Did the machine previously have rubber tracks, or are you converting to rubber?
Wanting to convert to rubber.
When I try to look it up I am not able to find any thing with this part #. I will probably have to look at Brismac or the like that sells the tractors to get this parts #. I was hoping for the dimensions so I could find a set from any rubber track supplier.
/ Tracks for chinese dozer. #7
I should have noted that the track frames are already drilled and threaded for the sixth roller.
I will try to get the numbers from my tracks today, but I kinda doubt any aftermarket track profile is going to fit. You should be able to order OEM tracks through Northern Tool or Circle-G Tractor.
You didn't fill out your profile location so I didn't know you're in AUSTRALIA! Yes, order through Brismac!
Ok thanks for the info. I'm in the US. Will give Northern tool or Circle-G a call.
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
11in. Bucket with Teeth Excavator Attachment (A64194)
11in. Bucket with...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
