Tracks for chinese dozer.
/ Tracks for chinese dozer. #1
bobgebroski
USA WV.
Yct306-3
Would anyone happen to know the correct size rubber tracks to fit on Yuchai / East Wind yct306 dozer. Thanks.
/ Tracks for chinese dozer. #2
Did the machine previously have rubber tracks, or are you converting to rubber?
Wanting to convert to rubber.
When I try to look it up I am not able to find any thing with this part #. I will probably have to look at Brismac or the like that sells the tractors to get this parts #. I was hoping for the dimensions so I could find a set from any rubber track supplier.
/ Tracks for chinese dozer. #7
I should have noted that the track frames are already drilled and threaded for the sixth roller.
I will try to get the numbers from my tracks today, but I kinda doubt any aftermarket track profile is going to fit. You should be able to order OEM tracks through Northern Tool or Circle-G Tractor.
You didn't fill out your profile location so I didn't know you're in AUSTRALIA! Yes, order through Brismac!
Ok thanks for the info. I'm in the US. Will give Northern tool or Circle-G a call.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
