Tracks for chinese dozer.
/ Tracks for chinese dozer. #1
bobgebroski
USA WV.
Yct306-3
Would anyone happen to know the correct size rubber tracks to fit on Yuchai / East Wind yct306 dozer. Thanks.
/ Tracks for chinese dozer. #2
Did the machine previously have rubber tracks, or are you converting to rubber?
Wanting to convert to rubber.
When I try to look it up I am not able to find any thing with this part #. I will probably have to look at Brismac or the like that sells the tractors to get this parts #. I was hoping for the dimensions so I could find a set from any rubber track supplier.
/ Tracks for chinese dozer. #7
I should have noted that the track frames are already drilled and threaded for the sixth roller.
I will try to get the numbers from my tracks today, but I kinda doubt any aftermarket track profile is going to fit. You should be able to order OEM tracks through Northern Tool or Circle-G Tractor.
You didn't fill out your profile location so I didn't know you're in AUSTRALIA! Yes, order through Brismac!
Ok thanks for the info. I'm in the US. Will give Northern tool or Circle-G a call.
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2015 John Deere CX15 (A64126)
2015 John Deere...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
Asphalt Melter (A61572)
Asphalt Melter...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
