Tracks for chinese dozer.
/ Tracks for chinese dozer. #1
bobgebroski
USA WV.
Yct306-3
Would anyone happen to know the correct size rubber tracks to fit on Yuchai / East Wind yct306 dozer. Thanks.
/ Tracks for chinese dozer. #2
Did the machine previously have rubber tracks, or are you converting to rubber?
Wanting to convert to rubber.
When I try to look it up I am not able to find any thing with this part #. I will probably have to look at Brismac or the like that sells the tractors to get this parts #. I was hoping for the dimensions so I could find a set from any rubber track supplier.
/ Tracks for chinese dozer. #7
I should have noted that the track frames are already drilled and threaded for the sixth roller.
I will try to get the numbers from my tracks today, but I kinda doubt any aftermarket track profile is going to fit. You should be able to order OEM tracks through Northern Tool or Circle-G Tractor.
You didn't fill out your profile location so I didn't know you're in AUSTRALIA! Yes, order through Brismac!
Ok thanks for the info. I'm in the US. Will give Northern tool or Circle-G a call.
