BeeferMan
toughest thing to get a bucket full of is manure with hay mixed in...
I guess you haven't been too many places where people really use tractors...I've seen cracked frame rails on 4440 JD's, busted front axles on about any color...loaders when used hard, and used alot take their toll eventually. I know the mid hp Ford SOS's had somewhat of a tendancy to spit if used alot
Explain how this is possible for the fulcrum to LOOSE contact with the ground when the loader is loaded? This is what is happening when you put a load in your loader right? If we agree that the fulcrum is the rear axle, how could loading the bucket possible remove weight from the pivot point? The most stress is on the front, and even if you put a counter weight on the rear, the most stress continues to be on the front axle, you've just got a buddy on the back of your teeter totter to help keep your tail on the ground. Here's an experiment you can try at home. You'll need 2-5 gallon buckets of water, and 2 bathroom scales. Place both scales in a position where you can place 1 foot on each. Do so and record the weights for each. Now pick up 1 bucket in 1 hand and hold out to the side, for this example we'll say that's your left hand. Note the change in weights and record. Now pick up the other bucket in the other hand, and hold out to the opposite side, in this experiment, your right. Note the change in weights. While I haven't personally done this, I believe the hypothesis will prove true...you're not reducing any weight on your left (the loader) by carrying some weight with your right (the rear of the tractor), but you're going to keep your machine more balanced. I'll give you balance and stability, but will disagree that you're reducing any weight on the front axle by carrying a counter balance. The loader is effectively a big lever, with the tipping point on the front axle, and hooked under the mid point of the tractor. Another test...go scoop a big bucket of dirt or rock with your loader, note the amount of squat in the front tires and the steering effort required with that load. Now go hook on your ballast box and get a similar bucket, does the impact to the front tires or the steering effort change? I'd bet not
I've got 3 sets of wheel weights already on my tractor, I prefer iron to CaCL, at least I can see the rust if it occurs that way. But I still disagree that adding rear ballast will reduce weight on the front axle. I have weight on my rear axle to offset the weight of the loader, but I run a higher risk of overloading my front. In no way can this added weight lower the amount of weight my front axle carries during loader operation that I can see. Not until you lift the load pretty high into the air does alot of weight shift to the rear axle...if my view of geometry isn't failing me, and at that point, it is the loader that is transfering weight to the rear, not the ballast box. Maybe someone can draw a picture that explains how it is possible. Does rear weight help? Absolutely, it does several things, it adds stability to keep the rear wheels down on the ground, and by doing that, it lets the rear wheels pull to move the tractor rather than asking the front axle in the case of a FWA. In my case I only have a 2wd tractor, so rear weight lets me move with a load.
nwbearcat,
I often find it helpful when analyzing a system to think of things in the extreme. Imagine a small 2,000 lb. tractor with a FEL without anything in the bucket. We'll assume the weight is split 50/50 between the front and rear axles (1,000 lbs. carried on each axle).
Now fill the bucket with a dense material (ie concrete) to the point where the rear tires just being to come off the ground. Now the front axle is carrying all of the weight of the tractor (2,000 lbs.) plus the weight of the dense material in the bucket. This is easy to follow and makes sense, right?
Now take that same fully loaded tractor and add a ballast box to the 3-point hitch, spaced 5' behind the rear axle. Now add a huge (say 5-10,000 lb.) weight to the ballast box until the front axle of the tractor comes off of the ground. Now does the concept make sense? It's complicated because it is a 2-fulcrum system in which one or both fulcrum points can react part of the load.
Now as the weight in the ballast box is slowly reduced, pound by pound, the load carried by the front axle begins to increase from zero. At some point the manufacturer determines some amount of weight to be best for overall durability of the system, this is the idea of a counterweight.
Now I will say that tractor manufactures typically recommend some amount weight to be added to the rear of the tractor, but they don't specify how far behind the rear axle this weight should be. The distance the weight is from the rear axle has a huge effect on how beneficial this ballast actually is.
Also, you are correct that adding ballast can increase the stress induced into the tractor frame. The added loads (loader bucket and ballast) are both outside of the reaction points where the load is carried to the ground (front and rear axles). This creates a large bending load near the center of the tractor/frame.
Hope this helps,
Josh
The good value of the [clipped] part of your post to refute nwbearcat aside, you are missing something in your side note. ... The sand bag position is safer over the rear axle. It gives added drive traction weight w/o subtracting steering traction. - - Now, in the specific condition where youre just trying to make it up that hill, move the weight [temporarily] back to the rearmost point of the vehicle.Im sorry, i just had to respond to this post.....
Yes, go ahead and do YOUR exercise that you think works....if you havent even done it, you can't possibly understand that you have the physics of this problem wrong...
your hypothesis will be wrong....
[snip]
As a side note, an amused observer, me, observes the futility and fallacy of people who put sand bags in their vehicles over the rear axle instead of at the rearmost portion of the trunk, to improve weight on the rear axle in the winter....lol...physics class isn't for everyone..
not sure if this one has been mentioned? But so far the most difficult thing I have found to try loading/moving is leaves...
Try a pile of good old Maine marine clay, dry or wet.....
One of the hardest things for me to scoop up with the loader is cut split firewood. You never get a good load in a conventional bucket.
I hear that. The wood seems to just want to move away and not be scooped into the bucket. Getting one layer on the bucket's bottom is an accomplishment.
Here are a couple of pictures for the ballast portion of this discussion.
Never happen. I declare myself the winner with the pictures above.I'm now eager to see this thread develop into a "Oddest Ballast" discussion.
I just have my Loader Buddy! You forgot to mention rocks!
I think Loader Buddy has that dealt with. Lotsless force needed & good ability to pick up.The hardest thing I've found to load is big rip-rap (bowling ball to basketball size boulders) mixed about 50/50 with wet clay. The whole pile just bonds together in one big mesh. It's very difficult to break loose a bucket full because one or more boulders is always locked to another one deeper into the pile. I ended up simply back-dragging the pile apart and then loading the boulders separately (by hand) into the bucket. What a PITA it was! You need a lot of breakout force to overcome this situation.
