pat32rf
I find that digging in rocky ground, or just trying to get stones in athe bucket can be frustrating with no toothbar. Thats why I built a stone bucket......also works for rooting out saplings or carrying brush.
I always keep a couple small piles of gravel (1-2 tons) at the top of our road for general road repair and winter use to get better traction when icy. Unfortunately, during our last snow, I had used all the washed stone and decided to use material out of the road bond pile (stone & crushed material). Was I in for a surprise...
The freeze/thaw/freeze conditions had transformed that gravel pile into nothing short of a cement dome that I could't penetrate with a toothbar on my loader. Literally stopped my machine dead in it's tracks! Had to turn the unit around and chip away with the backhoe, then break up with shovel. Took about 2 hrs to do a 30 minute job.
A lot of truth in your statement and I can relate.I read this topic differently - I have the hardest time with light material, i.e. mulch, compost, etc. A free standing pile of such things will "move" on you when trying to get a full bucket.
It is my OPINION (FWIW) that front axles SHOULD be able to carry across reasonably rough ground whatever the loader can lift, without undue wear or premature failure.
QUOTE]
I wholeheartedly agree with this statement.
However, if you take a look at the weight rating of R1s, you will see it is very easy to overload those tires. I think that is where weight behind the rear axle really helps.
I was looking at a Kubota M7040 the other day. It had R1s on it and the front tire rating was 1800 lbs. That is 3600 pounds for both tires. That tractor is approximately 5k lbs. without the loader. I would guess the loader is close to 2k lbs. Not sure how much of that weight is on the front, but that does not leave much for the bucket.
Read the tractor's manual about ballasting your machine.
Tractor manufacturers sell ballast boxes for a reason, and they've been around for many decades.
Making do with what you have. Tobacco has been around for along time, but that doesn't make it good for you
One reason is, of course, to improve rear wheel traction when necessary.
Another is to improve stability and another is to reduce the load on the front axle by acting as a counterweight.
Counter weight yes..reducing load on the FRONT axle no, add weight to the rear yes.
Otherwise, when using the loader to it's capacity (the relief valve in the system will let go before the system is excessively taxed), there is a substantial load on that front axle, even when worked within it's capacity. As you wrote in your post "somewhere there is a fulcrum"...that's the rear axle.
Explain how this is possible for the fulcrum to LOOSE contact with the ground when the loader is loaded? This is what is happening when you put a load in your loader right? If we agree that the fulcrum is the rear axle, how could loading the bucket possible remove weight from the pivot point? The most stress is on the front, and even if you put a counter weight on the rear, the most stress continues to be on the front axle, you've just got a buddy on the back of your teeter totter to help keep your tail on the ground. Here's an experiment you can try at home. You'll need 2-5 gallon buckets of water, and 2 bathroom scales. Place both scales in a position where you can place 1 foot on each. Do so and record the weights for each. Now pick up 1 bucket in 1 hand and hold out to the side, for this example we'll say that's your left hand. Note the change in weights and record. Now pick up the other bucket in the other hand, and hold out to the opposite side, in this experiment, your right. Note the change in weights. While I haven't personally done this, I believe the hypothesis will prove true...you're not reducing any weight on your left (the loader) by carrying some weight with your right (the rear of the tractor), but you're going to keep your machine more balanced. I'll give you balance and stability, but will disagree that you're reducing any weight on the front axle by carrying a counter balance. The loader is effectively a big lever, with the tipping point on the front axle, and hooked under the mid point of the tractor. Another test...go scoop a big bucket of dirt or rock with your loader, note the amount of squat in the front tires and the steering effort required with that load. Now go hook on your ballast box and get a similar bucket, does the impact to the front tires or the steering effort change? I'd bet not
Before you respond hastily, give that some thought or do some research. You might learn something.
Didn't know you timed my response...but yes, I've been observing for a while, just signed up for a user id recently, and have logged more than a couple hours on a tractor
And here's one for you...that FEL should be removed when not using it. The intent is to reduce wear on the front axle, pivots and such.
Deere recommends ballast (both front and rear, depending on the task at hand). Deere also recommends removing ballast when not necessary to extend drive train life. Since many of us do use that extra weight of the loader for front ballast (bush hogging, for example), one should remove that extra weight when not using it. As an example, my loader is off from Spring until Fall unless I have a specific need for it. I'll also drop the bucket off to reduce weight (buckets are heavy!!) when I have the loader on (if I know I'm going to be needing the loader in the near future).
Of course, not all loaders are removable or quick attach.
But you said that the fulcrum is the rear axle...why would leaving the loader on when you have a weight on the back of the tractor result in any wear to the front axle or pivots?.
As far as cracked castings...I've never read of or heard of someone breaking a casting using rear ballast (there was a relatively recent thread (Deere forum) which discussed an owner breaking the upper link attaching point, but that wasn't due to ballasting). I have read (on all the dedicated tractor forums on TBN) of folks breaking their tractors using 3ph backhoes (easy to overstress with a backhoe that isn't tied to the frame like the front end loaders are).
I initially worried when I saw the "squish" on the front tires, but it held up fine....
I guess you haven't been too many places where people really use tractors...I've seen cracked frame rails on 4440 JD's, busted front axles on about any color...loaders when used hard, and used alot take their toll eventually. I know the mid hp Ford SOS's had somewhat of a tendancy to spit if used alot
I have ordered 12yds. of Loam to fill in some holes and low spots in my yard, get some new grass growing. I am wondering how the 770 will perform getting into the pile.?? I'll have my ballast box on for sure as the Loam will be quite heavy, I assume. I find that the BB improves production greatly.
So, what material is the toughest to get a bucket load of.?? Rock.?? 3" Gravel.?? Loam.?? You tell me.......
I had trouble with air.
Not much use responding to your post...do what ever you want.
But do some research on the web about ballasting your tractor.
Water!:laughing:
I've got 3 sets of wheel weights already on my tractor, I prefer iron to CaCL, at least I can see the rust if it occurs that way. But I still disagree that adding rear ballast will reduce weight on the front axle. I have weight on my rear axle to offset the weight of the loader, but I run a higher risk of overloading my front. In no way can this added weight lower the amount of weight my front axle carries during loader operation that I can see. Not until you lift the load pretty high into the air does alot of weight shift to the rear axle...if my view of geometry isn't failing me, and at that point, it is the loader that is transfering weight to the rear, not the ballast box. Maybe someone can draw a picture that explains how it is possible. Does rear weight help? Absolutely, it does several things, it adds stability to keep the rear wheels down on the ground, and by doing that, it lets the rear wheels pull to move the tractor rather than asking the front axle in the case of a FWA. In my case I only have a 2wd tractor, so rear weight lets me move with a load.
QUOTE]
I think we're about to dive off on yet another tangent.
SOMEwhere it has to be acknowledged that R1s and fully loaded FEL buckets are NOT a good mix.
I've been wrong before, but methinks R4s are more suited for loader work.
In fact as "industrial" tires I would guess that to be their purpose.
I think of R1s as "agricultural tires".
ymmv, etc.
Anyway, not wanting to argue about it, but if you have the chance to check out same/similar M7040 with R4s on it - I would be curious to know what their load rating is.
I will be suitably embarrassed if it is less than or equal to (-:
I just have my Loader Buddy! You forgot to mention rocks!Before I got a tooth bar, I found the hardest things to load/move with a plain FEL bucket were (1) mixed manure/hay/straw, (2) hard-packed rocky ground/dirt, (3) brush/branches/trimmings, (4) anything frozen.
For the last of these, I now not only have a tooth bar, but also a grapple rake.
BOB
