torque specs for B&S 12.5
/ torque specs for B&S 12.5 #1
jimmoore
Platinum Member
Augusta, AR
05 CASE IH D35 W/FEL
Anyone know the torque specs for a 12.5 Briggs & Stratton model 28V707 type 1170 need specs for heads and rod caps. One year old machine is hogging oil and smoking badly. I have replaced the crankcase breather assy. I think I have a broken oil ring as it has lots of power and runs well, also easy to start. The other mower bought at the same time has no problems, its the same type and model. I can get parts at local auto syore but no specs. Any help will be appreciated.
jim
/ torque specs for B&S 12.5 #2
Jim, It's been awhile, but is'nt that an overhead valve engine?
If it is, before you do a full tear-down, pull the head and see if the head gasket is blown between the lifter galley and cyl. Seen that more than once. For your specs just drop by your B&S dealer (highly recommend the factory parts over NAPA)
Kubmech & Gorden. It is A L head engine, could not find specs on B&S website . The auto parts store in town handles genuine B&S parts & has microfilms of engines and part numbers but they don't show torque specs, THANKS anyway
jim
I sent JohnMillerIII a private e-mail yesterday, but he hasn't answered yet. He can come with about anything instantly.
jim
/ torque specs for B&S 12.5 #6
Jim
I just order parts for a Tecumseh from Small Engine Warehouse in Tulsa. They have a website and apparently most parts must be in stock because the engine I ordered for is 20-30 years old and the stuff, (rod, rings, piston, gaskets) was here in 4 days. They also had a manual for the engine. Reason I ordered from them is that I ordered the manual from my local dealer the week before Memorial Day. (It still isn't here.) These guys had it in my mailbox in under a week. Pricing isn't bad either and they can probably give you the torque specs when you call in an order. If you want, I can look up the website address for you.
SHF
Steven, thanks but I will contact a small engine repairman here in town ,he will most likely give me the specs, thanks again
jim
Stan, thanks a bunch! the engine is a single cylinder. I looked at a friends engine and it was a 28S series and and I could not tell any difference in the engines. I don't know what the V stands for.
jim
/ torque specs for B&S 12.5 #11
Let's see if i got this straight:
First two digits indicate displacement/ 28 cubic inches.
Third digit/letter indicates design series/V
Fourth digit indicates/vertical crankshaft, Flo-jet carberator and mechanical governor.
Fifth digit indicates/plain bearing
Sixth digit indicates/Electric starter-12 volt gear drive, with alternator.
Type number identifies unique features such as the crankshaft(output shaft size) or governor springs used on that engine.
The code number indicates assembly date and manufactoring plant.
year.........month...........day............assy. line and plant......
01 ......... 08 ............. 08 ...................... 01..................
Found my old Briggs book,
Head torque 165 "lbs
Rod cap 185 "lbs
Sump bolts 140 "lbs
........................Head torque sequence.............................
.................................... TOP........................................
................................3 .............. 2...............................
...........................5 ......................... 8.........................
.............................7 *........... @....6.............................
...............................1*...................4...........................
.........................................9*......................................
* Long bolts
@ Spark plug hole
. Ignore these, (who needs a scanner/w3tcompact/icons/smile.gif)
Kubmech, thanks for the info.
jim
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
John Deere 8400 (A64126)
John Deere 8400...
KSI Conveyor (A63688)
213121 (A64276)
213121 (A64276)
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
