FordnMassey
- Joined
- Jan 22, 2022
- Messages
- 171
- Tractor
- ford 3000 and MF35
Hi,
I have a Briggs and Stratton Endurance 20hp motor in a Husqvarna ride on mower. This is a single cylinder OHV motor. Recently it started blowing blue smoke suddenly while working hard cutting long grass and has continued since. It has 109h on it. The oil was changed at 50 and 100 hours and Husqvarna 10/30 oil was used. After the smoking started, the oil was changed for Penrite 30w mineral oil (a reputable Australian brand for those elsewhere). The smoking continues.
Spark plug removed and found oily. Dry compression test, throttle open, starter cranking, 100 psi. There is significant blow by - oil sprays out the oil filler pipe when running and fumes swirl in the oil filler pipe after stopping.
Numbers to identify the engine are:
Engine Serial Number on sticker:130920 ZD 86480
Number stamped on exhaust manifold tube: 581880901
I was wondering if anyone could help with the following:
1). Does anyone know the compression ratio on this motor?
2). Does anyone have the expected compression test results?
3). can I perform a wet compression test on a horizontal cylinder?
4). Does anyone know if the rings and or head gasket are susceptible to failing at 100 hours?
Thanks in advance.
FordnMassey
Thanks in advance.
FordnMassey
