Top Handle trimming Chainsaw.
   / Top Handle trimming Chainsaw. #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I have a husky 55 with a 20" bar which is a great saw and use it for the bigger stuff, but trimming and doing some things in tree's etc it is pretty big and really heavy.
I have an older Poulan 16" standard that is getting long in the tooth and starting to run crappy. I think it has reached a bit past it's life expectancy.
I got looking at these
Echo outdoor power equipment – Chain Saws, lawn care tools and more
The local Home despot has them in stock at about $259 (kills me their website says $200 but prices may vary)
Feels funny in my hands with the two hands so close together but my buddy the Arborist says this is the way to go, particularly if I am going to climb and limb (one of the projects that needs doing)
He run's all Stihls, but says for the money, and my usage, go with this Echo.
Anyone have insights or input?
   / Top Handle trimming Chainsaw. #2
I have a 20" Echo. I love it. I know a lot of arborists favor the top handle Echos. I need one, too. Right now, just too much other stuff in the way. :(
Can I borrow yours? :D
   / Top Handle trimming Chainsaw. #3
I have a friend who is an arborist. He has a couple of those saws. He uses a Husky that is similar top handle. He has a couple of Echo's that he lets the guys use in case they drop them. They work well, but he uses Husky, and sometimes Stihl as his personal saw.
   / Top Handle trimming Chainsaw. #4
You should stay with a Husky. The 334 saw is a top handle saw and can be found fairly cheap compaired to the 338xp or the Sthil top handle saw.
The top handle saws are designed for use up in the trees. Be carefull when using them on the ground.
The other neat Husky saw is the 336 or the 339. They have over sized handles on them, but are the traditional saw design, intended for use in a bucket truck. They have a very nice balance too.
Echo, Tanaka, Sthil, Jonsered and Domar all offfer a top handle design saw.
Take a good look around.
Well, I went with the Echo, and was very pleasantly suprised.
One of the dealers in town that I had a bad taste after a deal was showing as being an Echo Dealer. I do like to support local dealers moreso then box stores, and is worth a couple extra dollars to me. Also, while I do agree that as a factory service center, he will fix whatever Echo saw I bring him, I honestly believe that having bought the saw from him, will give me just a touch better service then had I bought it somewhere else.
Anyway, Saw at HD $259 14" bar. Saw at Dave's, $239. No brainer here, go in to pick it up, has a 12" bar on it, ask Dave, Oh, you can have it either way (same money), no problem, but most like the 12" bar. Figure he handles more saws in a day then I do in a year, so OK, give the 12" a shot, Do you have an extra chain, sure, what cut, agressive, safety etc. etc. um, agressive, OK, here it is, how much? $13.95 usually (bout the same as Wal-mart runs through my mind) good deal, but since you are buying the saw, $12, better then Wal-mart I smile. Go to leave, hey, hold on a second, we need to gas and oil it and go through it with you. Then goes through it, running it, adjusting the oiler, showing me some "tricks" on side cover removing, best ways to hold, how much oil should spray when etc. etc. Making sure I know what to look for and what to check.
I pay, and figure I will stick it in my old saw case, go to the truck and it won't fit. Hmmm, walk back in, you have any used cases? Sure, they look around and find one, "how much", eh, you bought a saw, you can have it.
Sure did a big change on my opinion of that shop.
My money and I will be there again, and will probably not leave together. :)
It sure was nice to see a small shop be competitive on price, and over the top on service, all at the same time.
Snowridge, come on over and borrow it anytime, of course you will need to cut a couple limbs out of the top of one of these tree's for me before you go with it :) Nothing like climbing tree's when you are afraid of heights..... Then grab a running chainsaw in your hand............
   / Top Handle trimming Chainsaw. #6
Pardon my ignorance, but is there a such thing as a bottom handle chainsaw? I've never seen one. Just trying to figure out the difference. I understand the principle of a smaller, lighter-weight saw for trimming and easily handling, but when I googled Top Handle trimming chainsaw, it looks basically like any other saw, just lighter and smaller.:confused:
Podunk
It is more top handle or rear / back handle.
A top handle saw has the trigger directly over the center of balance, a "standard" or rear handle saw, the trigger is at the back of the saw, usually literally hanging behind the motor.
A top handle saw allows you to single handedly use the saw "fairly" easy, while a standard saw, you pretty much have to have both hands (or extremely strong wrists) as the weight of the saw is in front not underneath your hand.
I can go find pictures if you would like.
Here, look where this handle is in comparison to the one linked above, more specifically where the trigger is.
Sorry I do not know how to put the pictures in here, but if you go too the two links you will see what I mean I believe.
   / Top Handle trimming Chainsaw. #8
Echo outdoor power equipment Chain Saws, lawn care tools and more
Man, I always thought if you go with Husky or Stihl you never go back to anything other. Have you looked at the Husky 142? It is certainly a lighter saw than the 55 and a workhorse. I have the Husky 455 and a 141 both are good saws.
You should be able to pick up a Husky 142 for around $200. (don't think they offer the 141 any more)
You can also have the saw shipped to you and get extra chains and a hat from these guys!
Chain Saws - Husqvarna Chain Saws
I have a Husqavarna dealer in town so he will match any price I bring in to him if he can verify it. What I have found it is nice to have a dealer close at hand and he always has parts available and service if you need it.
Just my 2 cents
Wayne
   / Top Handle trimming Chainsaw. #9
I've got a Stihl and an Echo.
The Echo is my saw of choice when I'm up in a tree or limbing a few branches. It's lightweight, starts easy and comes with a rope ring tether.
My Echo is one generation older and has the primer bulb for starting.... it has performed flawlessly and other family members are always asking to borrow it.
I tried to buy another for my brother... my saw shop said the new Echo model no longer has the primer bulb in California and they have had isolated cases of hard starting when not used over a period of time.
Just my 2 cents
Wayne
I like my Husky, and had (I think it was) a 142 in my hand at Lowes a couple days ago, and yes, $200, but that is not a top handle saw, and it would take more of a man then I am to single hand that saw.
I also do like to buy / service local if possible, and the echo fit that bill, sounds like the husky does for you, but I looked through the Norwalk site and did not see the top handles. I looked several other places and did not notice / find them either (baileys, etc)
Correction on edit, I did find them on Baileys,
Bailey's - Husqvarna 338XPT Chainsaw with 14" Bar & Chain
The price kind of decided it for me. :) I am cheap or poor, depending on the company I keep :)
Sorry, I had missed it on Norwalk as well (think I overlooked because of price)
Husqvarna 338XPT Chain Saw Includes 3 Chains Total, Hat & T-Shirt "Increased Power, 45cc Engine" - 338XPT
Anyway, here is the comp Husky, but again, I just think more then I need (5 year consumer warranty on Echo is hard to beat :))
And crud, editing again, I thought I had looked, and like on the second Post J Walker mentioned the 334 but I was unable to find that one, I think you would have to have a dealer that had one around still to get it.
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2007 Ingersoll...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
