Tire loading
/ Tire loading #41
<font color="blue"> this exotic fluid: pure water.
</font>
Yup, that is my choice, too. I'm lucky enough to live where it doesn't freeze, so I have tubes in my tires (got enough thorn related flats that I had to) and they are filled about halfway with water.
One of the nice things about doing it this way is that when I do get a flat I can just drain the tire where ever it seems best and then don't have to worry about lugging around a sort of flat, loaded tire.
Works for me, though. I can't add external weights without doing some kind of welding, which I'm not prepared to do to a tractor that is working well for me. Unfortunately, to add the Kubota weights to the front would require me to remove the FEL (not enough clearance /forums/images/graemlins/mad.gif). So loading the tires is a pretty good choice (I don't do rowcropping just now, and use my lawn tractor to mow my lawn).
My fronts are almost "slicks", and when I replace them I'll have them filled with foam. Bit pricier, but would eliminate flats /forums/images/graemlins/grin.gif, and is heavier than water, I think.
/ Tire loading #42
Thanks for the responses & info.
FYI Casimir 4570 is an old blackpowder ctg but handloaded w/appropriate modern powders and jacketed (or lead) bullets in modern mfg guns it has become "modernized" and is a very effective short to medium range round.
Wanted and need FEL but with 1 horse, 1 pony (baby sitter for horse), 1 jackass (to pay for it all and do the heavy lifting) - all wifes, I'll get by without for now.
NY Yankee Fan thanks for the wt info. - veeeery interesting!
3050's info has led me to decide to see if I need the extra wt before I jump in and fill the tires - my Mahindra 5500 came w/2 rear wheel wt per side - maybe (I hope) I won't need to fill the tires. Duals would restrict the versitility of our tractors by limiting where we could get with them. I have some trees that I'll need to bush hog around that duals would be to wide to get between.
Thanks to ALL that have replied, I have read w/interest your comments, suggestions, and reasoning and it has all been enlighting.
4570Forever
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
Kubota M125X (A60462)
2025 JMR Tree Boom Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
1991 Duer 430HCD Towable Hydraulic Log Splitter (A59228)
1991 Duer 430HCD...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
