Tire loading
/ Tire loading #41
<font color="blue"> this exotic fluid: pure water.
</font>
Yup, that is my choice, too. I'm lucky enough to live where it doesn't freeze, so I have tubes in my tires (got enough thorn related flats that I had to) and they are filled about halfway with water.
One of the nice things about doing it this way is that when I do get a flat I can just drain the tire where ever it seems best and then don't have to worry about lugging around a sort of flat, loaded tire.
Works for me, though. I can't add external weights without doing some kind of welding, which I'm not prepared to do to a tractor that is working well for me. Unfortunately, to add the Kubota weights to the front would require me to remove the FEL (not enough clearance /forums/images/graemlins/mad.gif). So loading the tires is a pretty good choice (I don't do rowcropping just now, and use my lawn tractor to mow my lawn).
My fronts are almost "slicks", and when I replace them I'll have them filled with foam. Bit pricier, but would eliminate flats /forums/images/graemlins/grin.gif, and is heavier than water, I think.
/ Tire loading #42
Thanks for the responses & info.
FYI Casimir 4570 is an old blackpowder ctg but handloaded w/appropriate modern powders and jacketed (or lead) bullets in modern mfg guns it has become "modernized" and is a very effective short to medium range round.
Wanted and need FEL but with 1 horse, 1 pony (baby sitter for horse), 1 jackass (to pay for it all and do the heavy lifting) - all wifes, I'll get by without for now.
NY Yankee Fan thanks for the wt info. - veeeery interesting!
3050's info has led me to decide to see if I need the extra wt before I jump in and fill the tires - my Mahindra 5500 came w/2 rear wheel wt per side - maybe (I hope) I won't need to fill the tires. Duals would restrict the versitility of our tractors by limiting where we could get with them. I have some trees that I'll need to bush hog around that duals would be to wide to get between.
Thanks to ALL that have replied, I have read w/interest your comments, suggestions, and reasoning and it has all been enlighting.
4570Forever
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2012 Addco DH250-FM Towable Solar Message Board (A64553)
2012 Addco...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
MACDON FD235 - 35' DRAPER HEAD (A64278)
MACDON FD235 - 35'...
