Tire Tread and Gear Ratios
/ Tire Tread and Gear Ratios #1
oakhilltop
Bronze Member
New Hampshire
Massey Ferguson 1E.25
I am looking to upgrade, and two of the possibilities are Massey Fergusons. The 1M.25 and 1E.25. I want to get R14 tires for snow, but R14s are not available in these models. I asked the salesman to see if MF would be offering R14 in the near future. I think that MF offers R14 on some models. The salesman contacted the rep and here's the reply from the salesman after contacting the MF rep.
The industrial and turf are the only options I’m being told due to gear ratios with the R14. They can’t seem to size the tire properly with that style. That’s what my rep is telling me
I don't know what that means and wonder if someone does.
Is there a good way of buying a tractor and get tires not normally offered by the manufacturer? Maybe buy the tires that I want, take them to the dealer while the tractor is being prepped for sale and have them swap and load the tires. Then I sell the tires that came with the tractor.
/ Tire Tread and Gear Ratios #2
Those machines are descendants of the GC 1723E and GC 1725M and are good machines. There is a ratio in the gearing so that the front tires want to travel ever so slightly faster than the rears. Unless you plan to run your tractor on paved roads, I don't believe it makes a big difference. I think your plan to swap the tires is a good one, and you can find someone else other than the dealer to do that and load the tires if that's what you want, and they are unwilling to.
Good luck, Dick
/ Tire Tread and Gear Ratios #3
Knowing the brand and series of tires the manufacture tables should get you the Overall diameter and hopefully the loaded radius or circumference. With those numbers the alternative tires can be located by those numbers, or with a bit more math the ratio of the front to rear tires can be calculated and all the other tires sizes compared looking for the same ratio. Yes the tires and possibly the rims can be swapped around at the dealers, one issue that could rear it's ugly head would be warranty work if something in the drivetrain fails during the warranty period.
/ Tire Tread and Gear Ratios #4
Long shot but can you check Kubota or Deere models of similar size to what tires are offered. If have same size R1 or R4 and offer R14 would think those sizes would work on a Massey as well.
/ Tire Tread and Gear Ratios #5
Good luck, Dick
Another thing you could do is buy a second set of wheels and have R14's mounted on them. Then just use those for snow; in snow the ratio certainly won't matter.
About loading the tires: I doubt that loading the front tires is worth the effort and expense, they are just too small to make much difference. The rears will make a big difference, but then be aware that the wheels/tires are that much heavier and that much harder to take off and put on. There are wheel weights available.
/ Tire Tread and Gear Ratios #6
If the fronts don't exceed the rears the tractor (vehicle) will not turn worth a dang especially on slippery surfaces, snow mud, wet grass.
Thanks for the inputs.
I am only planning on loading the rear ... if any.
These MF models are hard to find right now. But if I decide that one of them is a match for what I want, then I think looking at the Kubota's offerings and possibly copying the tire sizes is a good idea.
I am also considering the turf tires with chains for the winter. I don't work in mud or loose dirt, so I don't need the AG tires. In my search for a tractor, I've noticed that some turf tires are similar to automotive tires, while some others have much deeper treads, almost like knobs. I would want the more aggressive turf tire and haven't seen the MF turf tires yet. There might be a 1E.25 at a dealer about an hour away and I hope to take a look at it if it is still there.
I was under the impression that I would be able to find R14s that match the sizes of the tires that come with the tractor, but (obviously) haven't looked at it much. One other possibility for the upgrade is the Kioti CX2510 which is available with R14s. I've been looking more at that, which is why I haven't delved into the tire issue too much yet. I want to check out the MF models, because I have some concerns about Kioti's support. My brother in law has had a CK2610 for 5 years with no issues, so I go back and forth on the support/reliability aspects. Either way, I'd at least like to take a good look at the MF models.
/ Tire Tread and Gear Ratios #8
It's common to overdrive the front wheels 3% over the rears.... less it won't turn... more = front tire wear.
/ Tire Tread and Gear Ratios #9
You can figure the ratio by knowing rolling circumference of both front and rear tires then applying the axle ratio the manufacturer uses.
The equation: rc of front x ar, divided by rc of rears.
This will fall anywhere between 1-5% depending on manufacturer.
/ Tire Tread and Gear Ratios #10
I feel you are going about this selection incorrectly.
The first thing is to consider what size tractor is applicable to your needs.
That’s the number 1 consideration above all else.
Tire selection can be manipulated.
In my experience using and selling tractors, is that the most encompassing combo are turfs coupled with chains.
I didn't mean to imply that I would base my decision on tires, but I do consider the R14s a plus. There are pluses and minuses for every model of tractor. And those have to be weighed in the final decision.
The quote that I have for the 1E.25 shows R15 x 19.5 6. It doesn't specify, but I'm guessing R4. The "6" is the number of plys? Would I be able to swap these R14 which are also R15 x 19.5? Maybe the circumference is different which could cause problems? I'm used to car tires, where you tell the dealer the size that you have and can buy all season or snow treads etc.
/ Tire Tread and Gear Ratios #12
Interesting. The earlier 1723 & 1725 (and probably all earlier GC's) have 18x8.50-10 & 26x12.0-12 tires. What's on the rear of the new ones?
BTW, all this ratio stuff is only really important if using 4-wheel drive, although I suppose it could have a minor effect if using a mid-mount mower.
This is cut an pasted from the quote.
• MF1E.25H Hydro Tractor
• MF1E.25 - HST Platform
• F27x8.50-15 6PR / R15x19.5 6
• FL2407 SS Loader - 60" Bucket
/ Tire Tread and Gear Ratios #14
You may want to take a look at Carlisle Versa Turfs, mix or match to get desired front lead. Im having trouble seeing rolling circumference specs on a wide selection of tires. You almost are stuck at buy em and try em.
/ Tire Tread and Gear Ratios #15
OK, forget most of what I said: it looks like this is a bigger machine than the GC's which only have a 48" bucket.
/ Tire Tread and Gear Ratios #16
Interesting MF seems to enjoy making it hard to find out the tire size being used on the small tractors.
That said an R15x19.5 is available as an R14;
If you are able to find R14's in the same sizes as the tires on the tractor your lead/lag ratio should be good.
When I look at MF 1E.25's on tractor house they seem split between R14's and R4's
Pardon Our Interruption
My Kioti CK 2620 had these sized radial R14's on her 27-8.5-15 fronts and 15-19.5, the rears when filled with beet juice added 330 pounds each supposedly.
/ Tire Tread and Gear Ratios #17
The same size as the tires on my Kioti CK2620 which are R14's.
I think the 1M.25 replaces the 1526 series, but I don't know much about MF series of tractors.
So I can swap in R14s for R4s if I can find the same size? Can the height from the rim to the top of the tread vary for the "same size" tires? And could that cause problems?
Initially, the tires were not that high on my list of pluses vs minuses of models because I thought if I really wanted the R14s, I could buy the "same size" and swap them. Hopefully during tractor prep at the dealer. After this thread, I'm wondering if I should move the tire consideration up a notch or two.
My top two considerations are price (of course) and reliability. I have a 400 foot driveway with a very steep grade and I need a tractor that will work every time during the winter. We have a turn out at the bottom where I park a car before a storm comes so that we can still get out. But if the tractor doesn't work, then walking up and down a steep hill with 8 inches of snow is not fun. Especially now that we are both 70, but luckily still in good health. We did get an Ego blower as a backup, but even using that on a steep grade is not fun. My very reliable JD 2305 is 16 years old now and I am concerned that time will start taking its toll on it. I'm hoping to get a new reliable tractor for the next 10 to 15 years, and get a little more capacity than the 2305.
/ Tire Tread and Gear Ratios #19
I feel you are putting too much credence on tread type.
Turfs are very good in snow because it is not the tread that grips snow. It is the snow on the tire that grips snow.
Once you add temps above freezing, no tread will do better than chains.
Any tire will do you as from your driveway description, I’d get chains no matter what the tire.
Forget about reliability as there is no objective measure for it.
What you need is capability and a larger tire with chains has more capability in snow on steep inclines than a tire w/o chains.
Do not rely on advertised tire size. There is no industry standard so yes, two tires of different make and or different tread with the same advertised tire size, can have differentiated circumference
/ Tire Tread and Gear Ratios #20
I have absolutely no use for R4 tires, they have never favorably impressed me once they get off hard dry pavement. I have used R1 almost all of the time. That said the R14's on my little Kioti have impressed me with their capabilities. They work very well in snow untill you do spin them and pack it into ice, then you had better hope you can back out of that spot and get back on fresh unpacked snow. R1's will work about the same very good intill they break out and spin and make ice.
The rear r14's, I did have too add spacers to have clearance for my chains,
before...................................................................after
These are the new BKT Ridemax tires I put on my Brason last fall, they have been an impressive tire on this tractor on snow and dirt and turf, they got into bit of mud during the spring and they did OK not as good as R1's but much better then R4's could have ever dreamed of doing.
Chained up and ready for winter, even with tires that work well in snow when it gets steep and packed or iced over nothing will work like good chains. These studded Euro patterned chains are the best I've found after many decades of using chains.
