Tire Tread and Gear Ratios
   / Tire Tread and Gear Ratios #21
Not sure about your application, but when I switched my old Kubota B8200 from R3 turf to R4, the rim size was different was different for turf vs R4. I looked at R1 and the rim size for the factory spec tire was a different size rim too(R1 was narrower tire and rim front and rear).
And, all of those setups varied in height, so matching tires and rims had to be right or else the overall gear ratio would be wrong and cause front end wear.
   / Tire Tread and Gear Ratios #22
It sounds like replacing all four tires of any tread pattern with four new tires of the same size of a different tread pattern may not always work. And maybe even the same tread pattern could be a problem. This seems really f'd up to me. Kinda like bicycle tires where a 26 x 1.75" tire and a 26 x 1 3/4" tire are different sizes.
But it's very possible that I'm still not getting it.
   / Tire Tread and Gear Ratios #24
You can figure the ratio by knowing rolling circumference of both front and rear tires then applying the axle ratio the manufacturer uses.
The equation: rc of front x ar, divided by rc of rears.
This will fall anywhere between 1-5% depending on manufacturer.
When I designed tractors at Deere... we'd use SLR: static loaded radius. In later years it got more difficult to get precise numbers from the manufacturers on their tires. Suppliers moving out of the segment? Production moving to low cost countries?
   / Tire Tread and Gear Ratios #25
The SLR is what I still look for when looking at tires, I have always been surprised that the SLR and the rolling circumference (RC) almost never agrees with the (2πr) with the loaded rolling circumference always being a bit over the loaded radius x 2 x pi., but always a long way from the diameter x pi.
which is what I can change with tire pressure.
   / Tire Tread and Gear Ratios #26
Growth of squirm losses within the contact patch.
   / Tire Tread and Gear Ratios #27
With the center of the rear axle being the origin (0,0,0) of the tractor model, the SLR determines the "ground plane".... all the lift systems relate to ground. Pretty big deal getting a good SLR number.
"Grown tire" is another number the tire manufacturers used to provide... not so much in recent years. Tires, of course, grow with age. Need to know how much to keep fenders, belly mowers, etc out of their path!
   / Tire Tread and Gear Ratios #28
Knowing the brand and series of tires the manufacture tables should get you the Overall diameter and hopefully the loaded radius or circumference. With those numbers the alternative tires can be located by those numbers, or with a bit more math the ratio of the front to rear tires can be calculated and all the other tires sizes compared looking for the same ratio. Yes the tires and possibly the rims can be swapped around at the dealers, one issue that could rear it's ugly head would be warranty work if something in the drivetrain fails during the warranty period.https://www.tractorbynet.com/forums/threads/tire-tread-and-gear-ratios.592608/reply?quote=7212057
That's right, except that the only number you really want to compare is the "Loaded Rolling Circumference" - sometmes known as just "LRC". Because a loaded tire is no longer a round shape with the axle in the middle, the average person can't get there by doing a simple calculation from radius or diameter. LRC is easy to measure; hard to calculate. Let the manufacturer measure it.
The good news is that some tire manufactures are now have an app on their website which allows you to choose any of their tire F/R pairs and it will report the LRC Lead/Lag ratio between those tires. Your tractor tire salesman ought to know that....but it's a newish app so he may not.
Then all you need to do is to look up your tractor's front to rear internal transmission ratio in the specs in the shop manual and choose tires to match. If the ratio is not in the specs any tractor mechanic can measure it.
Sometimes the tractor manufacturer will change that internal transmission ratio depending on what tires a buyer orders on a new tractor. It's a job best done when the tractor is being built.
I've done this several times now. Tire swaps can be a lot of work for what you get and often involves at least one set of new front or rear rims. I would recommend going with the manufacturer recomendation.
rScotty
   / Tire Tread and Gear Ratios #29
The reason why SLR doesn't work with simple 2 pi calculations is beause when a tire is loaded the axle is no longer in the center of a circle. The SLR is shorter between the axle and ground than it is between the axle and top of the tire.
So trying to get from Loaded Radius to calculate Loaded Rolling Circumference - known as LRC or just RC - is difficult because the shape is not round. Measuring either one directly on the ground is easy. Or just look up RC/LRC. It's in all the mfg tire specs.
   / Tire Tread and Gear Ratios #30
When you’re figuring out the lead ratio, go with the RC. Sure, SLR is easier to work with, but it doesn’t really reflect the tire’s actual squished circumference. Just use the RC from the manufacturer — it’s always measured at the rated air pressure anyway.
2006 SHOP MADE MARATHON 20KW GENERATOR TRAILER (A58216)
2006 SHOP MADE...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2016 Case 580N EP Backhoe Loader, S/N JJGN58EPLGC729072, Diesel Engine, 4 x 4, 80" Front GP Bucket, (A59076)
2016 Case 580N EP...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
