Dirt Moving Tips on using a scraper blade
/ Tips on using a scraper blade #21
thanks for the input
/ Tips on using a scraper blade #22
the dealer says that I can only have 3rear diverter on back of tractor so I need to be creative in order to have 4th valve for hyd. top link Icould use some input
/ Tips on using a scraper blade #23
The factory rear remotes can have one or two valve spools. Beyond that you need to add an additional valve body elsewhere. Mine's mounted on the fender. You can have as many spools in that one as you wish.
/ Tips on using a scraper blade #24
I believe that he has a Kubota M9540, he can have 3 factory rear remotes. He needs to get a diverter setup. If his tractor is a cab model, then the ROPS type mounted valve is not really an option.
Here is a picture of a customer that has 3 factory rear remotes and a triple diverter set. He operates his T&T and a rear blade with 4 hydraulics.
Sorry about the sideways picture. :ashamed:
/ Tips on using a scraper blade #25
Wow. Thanks for posting that picture. Very helpful. I want to copy that
For my M7060.
/ Tips on using a scraper blade #26
Oops this was in the Branson section so I thought he had a Branson.
That diverter setup is really clean. The switch logic must be interesting though.
/ Tips on using a scraper blade #27
That is what I need . Tkanks for the picture. Now if I can find one. I do have a cab on my m9540.
/ Tips on using a scraper blade #29
I am glad I found MtnViewRanch. Now I need the funds.
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
Wagon wheel Table (A64557)
Wagon wheel Table...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A64194)
2001 Freightliner...
