Thread Sealing Tape?
/ Thread Sealing Tape? #41
I have used teflon tape on hydraulic fittings for over 30 years and have never had a problem , I do a neat job or try to and have had zero issues.
I'm not one to say teflon tape is bad... but I worked for Teleck who is now Terex. They switched to dope after finding tape in spool valves.
/ Thread Sealing Tape? #42
For fuel or oil application on pipe threads I use a dab of Permatex Aviation Form A Gasket.
/ Thread Sealing Tape? #43
Teflon tape won't cause any problems if the person applies it PROPERLY. I've used it in automotive in many applications for about 50 years now and have never had a problem whereas I've seen guys apply it IMPROPERLY and cause the mentioned problems.
/ Thread Sealing Tape? #44
Yes Teflon tape can be used successfully, but it also can cause serious issues.
In most manufacturing plants, a Japanese manufacturing practice called Polk-yoke is commonly used when setting up standard manufacturing processes. Polk-yoke is simply designing a process so that the operator can't do it wrong. IE: it only goes together one way, all the screws are the same size, etc...
Polk-yoke your assembly and don't use Teflon tape, use a product designed for the application to make sure you don't have problems.
S/A Solar Towable Speed Trailer (A64194)
S/A Solar Towable...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Hustler FasTrak Zero Turn Mower (A66408)
Hustler FasTrak...
New/Unused ATS 80 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 80...
