Talk Me In/Out of the Stihl MS261
   / Talk Me In/Out of the Stihl MS261 #21
Not really because it's a 2 stoke engine, not a 4 stroke. Not here to debate anything except to say the 590 Timber Bear is one helluva chainsaw at a much better price than the Stihl. Not that I don't like Stihl's, just don't like the new over priced ones. I still use my 45 year old 028 AV and I own but don't use not only an 090G but an 075 as well.
The Timber Bear is made in Japan by Echo's parent company and imported to your friendly Echo dealer. In fact, my Kubota dealer has just taken on Echo.
   / Talk Me In/Out of the Stihl MS261 #22
Just a 3 acre homeowner myself....but my Farm Boss MS 290 is still serving me.....(although it is somtimes stubborn to start )...Later I treated myself to a MS 261 using a 20 inch bar.............and ....am real happy with both. The 261 is easier to start. I leave a 16" bar on the Farm Boss.
Cheers,
Mike
   / Talk Me In/Out of the Stihl MS261 #23
I just wanted to know your reasoning. I am assuming this was for me ?
If so it makes no sense, HP is HP and torque is torque and time is time on 4 stroke and 2 stroke no difference on dyno graph ... Y axis is HP on one side and torque on the other then X axis is RPMinutes (time) ... the chain size or bar size on a chainsaw is equivalent of the wheels size on a vehicle, cutting wood would be the equivalent of the load pulled by a vehicle or even wind resistance...
   / Talk Me In/Out of the Stihl MS261 #24
My 2 cents. The 250 or 261 is really not a 20" bar saw. I have an 026 pro with a muff mod that I use a 20" bar on that I use strictly for limbing. Works great for that but falls off on 10+" hardwood. It comes into it's own with a 16" bar for firewood cutting and is a little beast. I also use a 361 with a 20" and it's adequate. If you insist on a 20" bar you really should consider 60cc.
   / Talk Me In/Out of the Stihl MS261 #25
I just cut down 75 12”-40” trees with a 261C and a 20” bar with yellow skip chain. I also bucked them and cut them to 16’ and 24’ lengths for the log truck.
It was a great choice of saw. It’s light, but powerful. It’s also pretty affordable, yet still considered a “professional grade” Stihl saw.
I think you’ll be extremely pleased.
   / Talk Me In/Out of the Stihl MS261 #26
Dont do a 271 or 291. Not worth fixing IMO once those things go down. Plastic saws.
261 Gen2 Gen3 might be on Gen4 by now. Nice light like the 026 260 was. But I wouldnt want for bigger hardwoods. Sure they can cut bigger softwoods like spruce and pine. But hardwoods I be wanting more cc of a saw. $700
I would want the 400 66.7cc over the 362 59cc that it replaced for same weight. $1000
Best bang for the bucks with carbs you can tune yourself.
Echo 590 59cc entry level to their pro saw builds. Great saw with long stroke for bigger wood. $439
Echo 620 is the cadillac of the 59cc for echo. Has better stock porting then 590. rim drive, metal handle etc. $639
Down fall of the 59cc echos is the extra weight over stihls in same size. But you save 400 bucks or more too. 1lb more PHO dry as done by oem.
   / Talk Me In/Out of the Stihl MS261 #27
I've owned a small fleet of Stihls, from the little 019T top handle up to their largest 084 AV, at 122 cm3 displacement. I presently own a 63cc 036 PRO (older variant of MS362) and an 85cc 064 AV (small-bore 066 frame, replaced by MS660), among some other brands.
The MS291 is not going to satisfactorily pull a 20" bar with full comp chain and the nose buried in hardwood. Sorry, it's just not. Been there, done that.
If you keep the nose out of the wood, cutting stuff smaller than Ø20", or only cut softwood, or run skip chain, then you can get by with it. But an 18" bar is a much better fit for that 55cc saw, for anyone running full-comp chain in hardwoods. It's a great saw, but it's only 55cc!
I don't even run a full 20" exposed on my 63cc 036 PRO, since I'm cutting a lot of large diameter oak, and it's a little under-powered as soon as you get the nose buried. I found that saw works pretty well with 19" of exposed bar, which I achieve with large felling dogs on a 20" bar. Yes, it kind of looks silly having "big saw" dogs on a little 63cc saw, but it hits the sweet spot for that saw's power curve.
   / Talk Me In/Out of the Stihl MS261 #28
I have a MS 250 and bought a MS261. You won’t regret it, they seem like a lot of power for the weight. I have a 18” bar on mine but I think it‘d pull a 20” bar fine.
   / Talk Me In/Out of the Stihl MS261 #29
It also matters what chain you're running, and even how you sharpen it. I run full-chisel RS chain (or other brand equivalents), and take the depth gauges down .005" below factory spec. This cuts faster and throws bigger chips, but requires more horsepower per inch of bar, than those running semi-chisel chain at factory spec... or even worse, those who never adjust their depth gauges when sharpening!
   / Talk Me In/Out of the Stihl MS261 #30
FWIW a 20" bar lives on my 261. Mainly for limbing as it saves my back a bit but it has no issues buried in an oak or maple tree or log. Would a 60 or 70 cc saw be faster? Sure but at the cost of weight and $$. For kind of a do it all around the property saw the 261 is great. Keep the chain sharp and it will cut fine.
   / Talk Me In/Out of the Stihl MS261 #31
The 024/026/260/261 saws are great. I'm stihl using the 024AV my Dad got back in the early 1980's. That family is a very well balanced saw to work with.
That 024 is stihl a hard working saw; the Pro series saw has more than earned its keep over the last 40 years...
   / Talk Me In/Out of the Stihl MS261 #33
Lots of TBN'ers know a heck of alot about chainsaws....a whole lot more that I do. But many of us home owner types know what works for us. I really learn and enjoy these discussions.
Cheers,
Mike
   / Talk Me In/Out of the Stihl MS261 #34
A good 50 cc saw will certainly run a 20" bar, and if you bury it in Oak or Maple, it will still cut if the chain is sharp. (Been there, done that. If it's the saw already in my hands, sure, I'll use it for a cut or two.) However, in order to say it has "no issues" with that sort of use, you need one more thing: patience.
   / Talk Me In/Out of the Stihl MS261 #35
I’m down to a 462C or a MS500i to replace my Makita/Sachs, looking at clean used ones, but chainsaws are something I don’t like buying used.
The 261C cuts & screams above it’s size.
   / Talk Me In/Out of the Stihl MS261 #36
I’ve got a 500 and it’s a really good saw. You wouldn’t be disappointed with that option.
   / Talk Me In/Out of the Stihl MS261 #37
$150 more than 462 but you get .8 more HP and same weight
   / Talk Me In/Out of the Stihl MS261 #38
You'll forget the $150 real quick, but you'll remember the extra horsepower every time you use it.
   / Talk Me In/Out of the Stihl MS261 #39
Im not saying its the best option if you're regularly cutting wood that size but for most property owners its more than capable. Its also really not that slow, just cant horse it. Id rather carry around a 261 all day and maybe take a few more seconds to cut a big oak or maple tree than lug around a heavier saw just to save a few seconds on a handful of cuts. Obviously it all depends on the needs of the user.
   / Talk Me In/Out of the Stihl MS261 #40
This is so true. My 261 feels so feather light but with yellow chain cuts like a beast.
It IS a pro saw. Mugh more than a homeowner needs.
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2014 Ford Taurus Sedan (A59231)
2014 Ford Taurus...
