T474 Weight
/ T474 Weight #1
IronCladChad
TYM T474
I am hopefully moving a few states south this fall. I have a 16' double axle car hauler rated for 7k lbs. I'm guessing my T474 weighs 3600lbs + 1100 for the backhoe + 1k for the loaded tires. That puts me at about 5700lbs. I'll guess my trailer weighs 1500lbs. Maybe I can transport my bucket separately to save on weight.
Does anyone have a better estimate on weight?
/ T474 Weight #2
I would just comment that the spec base weight is 3230 - 3605 lbs without the loader. I assume the large spread is cab vs open station.
Assuming you have a front end loader....
The loader on my slightly smaller L4060 weighs in a at 1610 lbs with the bucket (331lbs). I would adjust your estimated machine weight up to 7300 lbs all in, which would be a problem.
/ T474 Weight #3
Is there a scale nearby? If I had questions about weight on my tractor, I’d run the mile to the scales, and weigh It. Then I’d drop the FEL, and find out how much it weighs. If I had a backhoe, I’d drop it to find out how much it weighs.
/ T474 Weight #4
For a T474, that's right up at maximized weight. I use my 2004 Chevy 1500 to haul mine, but I do not have loaded tires nor a backhoe. And my trailer is a 10k 20'', I'm 200# shy of my trucks max towing rate of 7800#, works good for the flat terrain I take my tractor to moving side jobs with. But if I had mountains passes I'd upgrade to a 3/4 ton.
/ T474 Weight #5
Interesting topic - I'm sure there are ton of threads on towing weights but this one interests me because of my own T474.
I have the cab, loader and weighted rears.
I believe I've calculated it out to needing about 8000# axels or 4k each.
My issue is I only have a F150 with 5.0 in it. 9000# towing capacity.
For what it's worth, I'm not worried about towing it - it's about stopping it.
Again, for what my opinion counts, I won't pull mine more than a few miles without a F250 or similar.
/ T474 Weight
Good to know. I don't have a cab but that's only a couple hundred lbs difference. I will probably end up having to use uship.
/ T474 Weight
I have the same truck. The brake controller should be able to stop it. I have to drive through the mountains so my truck isn't going to be enough.
/ T474 Weight #8
I have a 2000 Silverado 6 in lift with 35in tires. 5.3L Auto just under 300K miles. Trailer is 20ft 10K lb car hauler. T474,cab,loader, and backhoe. Truck pulls and stops(yes with brake controller) well-but works on hills. Trailer squats pretty good-not sure if an equipement trailer would handle it better? Pic is the day I brought Ole Red home
/ T474 Weight
Are your tires loaded?
/ T474 Weight #11
Old topic but relevant. Have you moved your 474 with your F150 5.0l a lot? Just wondering how it did and what trailer you have.
/ T474 Weight
No, my FIL used his f250 and a 10k trailer. My f150 would have **** a brick going up the hills
/ T474 Weight #13
My T574 is a bit bigger, but I did the math and decided I didn't want to buy a bigger truck just for the (hopefully) rare situations where I wanted to take my tractor off property. I have a stout trailer, but I made sure it wouldn't handle my tractor. This way I will not be tempted to 'try'.
/ T474 Weight #14
I brought my new T474 home on a 7K-LB equipment trailer shown in my avatar photo this past Friday (12/22) when leaving the dealership about 60 miles away. My Tow Vehicle (TV) is a '21 RAM 3500 Big Horn CC 4WD LB DRW w/CTD HD Torque. Truck had no problem, and the electric brakes on both axles of the trailer worked flawlessly.
Trailer had me a little worried as my calculated T474 HST weight was 5146-LBS per the manual with the loader and loaded rear wheels (+838-lbs). I was probably over the GVWR by a couple hundred pounds as I wasn't aware the rear tires were loaded until I questioned it at the dealership. Had I had that info before I left the house, I would have went to a 'stouter trailer'.
I won't tow the T474 again unless it's on a 7'x20-24' Equipment Trailer w/5200-LB axles (MINIMUM) or better yet dual 7K-LB axles with electric brakes on BOTH AXLES! YMMV...
213091 (A64276)
213091 (A64276)
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
Roll of Plastic Hose (A64119)
Roll of Plastic...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Wacker Neuson...
2019 John Deere R-4038 (A61306)
2019 John Deere...
