T-posts in hard ground - a hack
/ T-posts in hard ground - a hack #41
I had about 65 locations where the exposed bedrock made me use 2x4 - "L" posts. My neighbor has a commercial air compressor/jack hammer. This will be the final year where we replace the last "L" posts with T-145 steel posts. That jack hammer makes a 2" hole, about 16" deep, fairly quickly.
/ T-posts in hard ground - a hack #42
How big is the jack hammer? Do you have any info on model/cost.
/ T-posts in hard ground - a hack #43
Bill - the actual hammer is pretty big and it's heavy. The air supply comes from a three cylinder diesel mounted on a trailer. It's the type you see at highway construction projects. It is DEFINITELY not a homeowner model. He tows it around with his pickup. When he gets here - I tow it with my tractor. He let me try the hammer once. Got down about 6" and he took over. The major concern - getting the bit stuck in the hole you are drilling.
There is compressed air hissing everywhere - dust and rock chips flying all around. It makes quick work of our basaltic lava.
/ T-posts in hard ground - a hack #45
That's pretty slick. A very cute girl and a slick way to pull a T-post.
/ T-posts in hard ground - a hack #47
I have some exposed rock on my property. I bought the largest hammer/demo drill Makita makes (SDSmax) Purchased a 1.5'' drill bit and drilled the rock and hammered the T post into the hole.
No need to cement in as the 1.5'' hole is a very tight fit for T post.
You just have to knock the plate off the T post
/ T-posts in hard ground - a hack #48
Our clay soil doesn't give up a T post once shes been in the ground for a fw years. Takes a big tractor to pull em out and they take a lot of bonded dirt with them.
/ T-posts in hard ground - a hack #49
BTW - the augers I used re the original post/hack (putting in T-posts in hard ground) were these from Harbor Freight - inexpensive and do the job.
/ T-posts in hard ground - a hack #52
/ T-posts in hard ground - a hack #53
I have one, and have used it a half dozen times. You need a 2' 2x6" as a base as well, or it sinks into the soil, and it often takes a couple of lifts to get most posts out. I keep it around for locations where I can't use a chain and the FEL, and I can't budge the T-post by hand, so it gets used about once every other year. YMMV...
All the best,
Peter
/ T-posts in hard ground - a hack #54
/ T-posts in hard ground - a hack #55
I have one of the Agrisupply gas pounders. One of my better purchases. I've driven tposts through roots with it. I've had it 3 years. Only use non-ethanol fuel mixed with oil. Push the primer 3-4 times. Put choke on pull chord once turn choke off and pull cord to start. Only time it doesn't start is when I forget to slide the kill switch back to run.
It is heavy and it is loud. Hearing protection is a must.
If you have a helper and arms long enough you can drive them straight in through the hardest clay there is. Without a helper I start them with manual pounder lining up an entire string a few inches in the ground then go through with the gas pounder and drive them one after another.
Having them a few inches in keeps them from falling over while getting the gas pounder over the top of them. 6ft posts I can handle straight in the 6.5ft posts I need to get started. I will do 8 in a row then need to sit it down and rest my arms a bit.
I kill the engine rather than idle it anytime I am sitting it down. It always restarts first pull. It is also very fuel efficient.
/ T-posts in hard ground - a hack #57
I see powered post pounders for around $300.
Powered T-post pounder
Yeah, but if you scroll down to the 'specs' and 'compare'.... this one says it's "solar powered" and 110V ---- another says "wind power" ---- it must have something to do with the translation! :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:;)
/ T-posts in hard ground - a hack #58
For my rock hard clay pasture I rigged up a gas powered pressure washer, using a screw on tip I use it as a probe and go straight down and make a wet hole then the post drives easily into the wet hole.
Great idea!..... I bet it gets messy though!
/ T-posts in hard ground - a hack #60
A very good method. It’s also used to find underground pipe.
That's what I use it for all the time.
The prior owners on the ranch here put in pipes and electrical without reference to surface objects, e.g. not 2' out from a fence, or straight from a faucet. I've learned to get out the pressure washer and have a look-see before doing much underground. Wear gloves and solid boots, as pressure injuries are not a joke.
Oh, and yes, can be quite messy depending on the soil type, and whether you are doing a straight shot down for a T-post (not so bad), or excavating to find power lines (careful which way you point the nozzle).
All the best,
Peter
Unverferth 330 (A64119)
Unverferth 330...
2004 John Deere 4720 (A60462)
2004 John Deere...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
