T-posts in hard ground - a hack
/ T-posts in hard ground - a hack #41
I had about 65 locations where the exposed bedrock made me use 2x4 - "L" posts. My neighbor has a commercial air compressor/jack hammer. This will be the final year where we replace the last "L" posts with T-145 steel posts. That jack hammer makes a 2" hole, about 16" deep, fairly quickly.
/ T-posts in hard ground - a hack #42
How big is the jack hammer? Do you have any info on model/cost.
/ T-posts in hard ground - a hack #43
Bill - the actual hammer is pretty big and it's heavy. The air supply comes from a three cylinder diesel mounted on a trailer. It's the type you see at highway construction projects. It is DEFINITELY not a homeowner model. He tows it around with his pickup. When he gets here - I tow it with my tractor. He let me try the hammer once. Got down about 6" and he took over. The major concern - getting the bit stuck in the hole you are drilling.
There is compressed air hissing everywhere - dust and rock chips flying all around. It makes quick work of our basaltic lava.
/ T-posts in hard ground - a hack #45
That's pretty slick. A very cute girl and a slick way to pull a T-post.
/ T-posts in hard ground - a hack #47
I have some exposed rock on my property. I bought the largest hammer/demo drill Makita makes (SDSmax) Purchased a 1.5'' drill bit and drilled the rock and hammered the T post into the hole.
No need to cement in as the 1.5'' hole is a very tight fit for T post.
You just have to knock the plate off the T post
/ T-posts in hard ground - a hack #48
Our clay soil doesn't give up a T post once shes been in the ground for a fw years. Takes a big tractor to pull em out and they take a lot of bonded dirt with them.
/ T-posts in hard ground - a hack #49
BTW - the augers I used re the original post/hack (putting in T-posts in hard ground) were these from Harbor Freight - inexpensive and do the job.
/ T-posts in hard ground - a hack #52
/ T-posts in hard ground - a hack #53
I have one, and have used it a half dozen times. You need a 2' 2x6" as a base as well, or it sinks into the soil, and it often takes a couple of lifts to get most posts out. I keep it around for locations where I can't use a chain and the FEL, and I can't budge the T-post by hand, so it gets used about once every other year. YMMV...
All the best,
Peter
/ T-posts in hard ground - a hack #54
/ T-posts in hard ground - a hack #55
I have one of the Agrisupply gas pounders. One of my better purchases. I've driven tposts through roots with it. I've had it 3 years. Only use non-ethanol fuel mixed with oil. Push the primer 3-4 times. Put choke on pull chord once turn choke off and pull cord to start. Only time it doesn't start is when I forget to slide the kill switch back to run.
It is heavy and it is loud. Hearing protection is a must.
If you have a helper and arms long enough you can drive them straight in through the hardest clay there is. Without a helper I start them with manual pounder lining up an entire string a few inches in the ground then go through with the gas pounder and drive them one after another.
Having them a few inches in keeps them from falling over while getting the gas pounder over the top of them. 6ft posts I can handle straight in the 6.5ft posts I need to get started. I will do 8 in a row then need to sit it down and rest my arms a bit.
I kill the engine rather than idle it anytime I am sitting it down. It always restarts first pull. It is also very fuel efficient.
/ T-posts in hard ground - a hack #57
I see powered post pounders for around $300.
Powered T-post pounder
Yeah, but if you scroll down to the 'specs' and 'compare'.... this one says it's "solar powered" and 110V ---- another says "wind power" ---- it must have something to do with the translation! :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:;)
/ T-posts in hard ground - a hack #58
For my rock hard clay pasture I rigged up a gas powered pressure washer, using a screw on tip I use it as a probe and go straight down and make a wet hole then the post drives easily into the wet hole.
Great idea!..... I bet it gets messy though!
/ T-posts in hard ground - a hack #60
A very good method. It’s also used to find underground pipe.
That's what I use it for all the time.
The prior owners on the ranch here put in pipes and electrical without reference to surface objects, e.g. not 2' out from a fence, or straight from a faucet. I've learned to get out the pressure washer and have a look-see before doing much underground. Wear gloves and solid boots, as pressure injuries are not a joke.
Oh, and yes, can be quite messy depending on the soil type, and whether you are doing a straight shot down for a T-post (not so bad), or excavating to find power lines (careful which way you point the nozzle).
All the best,
Peter
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
6' Rotary Mower (A64119)
6' Rotary Mower...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
