Suggested "kit" for 3rd function?
/ Suggested "kit" for 3rd function? #1
Alpha Dog
Texas
Kubota L2800 DT, Kubota L275.
I recently added a 3rd Kubota, an L4701 to my "fleet." Seven or eight years ago, I installed a "Construction Attachments 3rd function kit" to my L2800, and had no problems in installation or in use since I got it. However, I can't find that "kit" specific for my L4701, and have been looking at what's available, and was wondering if anyone has current thoughts on their "preferred" 3rd function kit would be?
I like the "switch" on my CA kit, and use both tractors several times a week, so having a similar joystick control is important to me.
I see some of the new kits come with only "loose" hoses to the loader, rather than the bracket on the crossbar system I had before, so I'm wondering if there's some advantage to that?
Any ideas or suggestions?
/ Suggested "kit" for 3rd function? #2
I have a Landpride 3rd function kit on my MX5200. Well integrated. Remember Kubota owns Landpride
Andy
/ Suggested "kit" for 3rd function? #3
I have W&R Long 3rd function kits on both my L6060 and MX5800. The kits were reasonably priced and relatively easy to install with all necessary hoses and hardware included. On the MX5800, the control switch is located in a joystick knob which replaces the OEM. The wiring and control shaft are encased in shrink wrap which makes for a clean installation.
The switch on the L6060 is built into the OEM joystick and uses wiring already in place.
/ Suggested "kit" for 3rd function? #4
Below is the install instructions for the Land Pride third function on L4701. It has the bracket on the loader cross beam for the hoses. If I install a grapple on my L4701 this is what I am going to use.
  • 380-153m.pdf
KUBOTA MS-111 TRACTOR (A62130)
KUBOTA MS-111...
2003 Gradall XL3100 Highway Speed Wheeled Excavator (A61567)
2003 Gradall...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
BUNDLE OF ASSORTED LUMBER (A62131)
BUNDLE OF ASSORTED...
2015 Ford F-150 IN-OP at time of listing (A63118)
2015 Ford F-150...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
