Stump Pulling with 3-Point - Any concerns?
   / Stump Pulling with 3-Point - Any concerns? #31
Thanks all for your interest in my project and my safety, after many hours of seat time I have learned to mitigate the risk of a flip over by counter balancing with family members in the FEL :). Good information concerning possible damage to the 3-pt, not something I am interested in breaking so I will stick with the drag-bar and try a shorter chain or just cut the dang things flush with the ground. Take Care All!
I suspect one of these girls just might be a candidate for the job of "bucket ballast". :D
Not sure I said whose family members Mace, looks like your crew will do.
   / Stump Pulling with 3-Point - Any concerns? #33
   / Stump Pulling with 3-Point - Any concerns? #34
I know my tractors limits. I can skid large logs by using the 3PH and a short chain to lift the log and drag. I know from experience that on level ground, my tractor will break tractor WAY before it flips. HAving the loader up front is a must.
But its not something you learn overnight, and not something for a less than skilled operator to attempt.
Actually you are just as likely to be the one who gets seriously hurt or worse. Everyday trade experts with years of experience are killed. Experience can be a great enabler, right up until you don't have enough.
The OP was smart enough to ask. Pretty good chance that he is also smart enough to understand the cautions and warnings, understand the "don't do's" and the "must do's".
Only thing I would add to the other comments, start small, work your way up in size, take your time. Maybe get some help. From your post I think you have a pretty good handle on common sense. - its your best friend.
Remember take your time, Think before you do, be safe - and have fun with your project.
   / Stump Pulling with 3-Point - Any concerns? #35
Hi Mr. B,
Instead of flush cutting, try cutting them off 4-5' off the ground, then hook up a chain from your drawbar (below the axle) to about a foot below the top, this is similar to using the "Paul Bunyon's Hammer" technique in that it gives you a tall lever with the fulcrum down at the ground. We have used our B2320 to push and pull over trees in this manner. I will usually also cut a small groove for the chain to get caught in at the point of attachment to keep the chain from either slipping off of the top end as the trunk comes over, or from falling down before you start your pull.
Happy and safe tractoring,
Thomas
   / Stump Pulling with 3-Point - Any concerns? #36
I like my odds alot better than a newbie/unskilled operator attaching to the 3PH and trying to pull stumps.
   / Stump Pulling with 3-Point - Any concerns? #37
Getting the extra weight on the back sure helps in the traction department.
   / Stump Pulling with 3-Point - Any concerns? #39
Not disputing that.
My point was to say is who are you to judge the experience / ability of someone you have never met? Answer his question - can this be done. Give him the whole answer including the warnings and cautions. You cannot gain experience if you never try. Very few have the opportunity to grow up around tractors and farms, however there are a lot of people with small tractors nowdays.
I applaud those that have the sense to ask questions first. That is one of the reasons for websites like this.
If the answer is simply "don't do this - it's too dangerous" then that is the answer, period. If it is dangerous, experience doesn't matter. It just means that you knew it was dangerous BEFORE you did it.
Granted there are many cases where experienced operators can do more than a novice. In some cases the best answer is "go find someone with experience doing this to help you".
Stump pulling is something that a lot of folks are going to do. SHARE YOUR EXPERIENCE. Here is what to do and this is what not to do. The rest is up to the individual. My belief is that if someone is smart enough to seek the advice of others, they are usually smart enough to follow it - proivided that they are given the whole answer.
Experience & confidence get people hurt just as much as the lack of it does - its up to the smarts of the individual. How many times has someone said "I don't know why Joe got killed doing that - he knew better....".
You apparently didn't like my comment that challenged your ability. I would submit that the OP might have felt the same.
Just my 2 cents.
   / Stump Pulling with 3-Point - Any concerns? #40
I can judge whoever I want and however I want. That is why it is MY opinion. And regardless of experience, I would NEVER recommend ANYONE, on here or in the real world, to attempt to pull stumps with the 3PH. It is dangerous. Yes I do it. I know it is dangerous. THATS why I dont suggest anyone else do it.
I did answer his question. Why does everyone keep saying that I Just said "dont do it...too dangerous". Re-read my post. And re-read the posts prior to it. The whole story was given by more than one other person. There is severe flip-over risk due to the elevated hitch, and added traction. I dont know what else to add???? If you want me to add words of caution, and suggestions on how to do it without flipping over, simple....pull from the drawbar. I am NOT about to advise someone how to pull from the 3PH. There are lots of things going on, and lots to go wrong. The last thing I want is someone going out there, following my advise, and end up dead under their tractor.
So quite simply, the warning and caution is, DONT DO IT. And the advise is PULL FROM THE FIXED DRAWBAR.
Now if the OP decides to do it anyway, thats his call. But it wont be because I advised him it was ok if you do this, and do that, and go slow, etc......
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2018 JLG 600S TELESCOPIC BOOM LIFT (A52709)
2018 JLG 600S...
