Stump Pulling with 3-Point - Any concerns?
/ Stump Pulling with 3-Point - Any concerns? #1
Beltzington
Appling, Georgia
JD 3720
I have a 100+ small pine trees (2-4" diameter) I want to remove, some around my pond are not conducive to pulling out with a longer chain. I have a very heavy duty 3-point 2" trailer hitch adapter and my thought was using this with a short chain I could lift the pine stump out of the ground. Tractor is a large 36hp PTO CUTs with a Cat1.
/ Stump Pulling with 3-Point - Any concerns? #2
Probably work if they're no bigger than that. Tree might land on you though.
/ Stump Pulling with 3-Point - Any concerns? #3
If you raise the three-point up very high and then drive forward you risk rolling the tractor up and over. The pull down on the rear gives the back tires incredible traction and the tractor can rotate right over. So you need to be very careful. Years ago I tried pulling a really small (maybe 4") oak tree with a large tractor and pulled the chain in two. I was impressed with the strength of that 90HP utility tractor, and even more impressed with how well that tree was anchored. I ended up digging down a ways and cutting the tap root.
/ Stump Pulling with 3-Point - Any concerns? #4
/ Stump Pulling with 3-Point - Any concerns? #5
If it were me, I wouldn't use the method that you described. Does your tractor have a Drawbar? You will be surprised at the root systems of even small trees. If you have a FEL, dig around the trees and pull with a chain or strap. How tall are the pines, what is the slope around your pond and exactly why are the trees not conductive by utilizing a short chain and not a longer chain? Pulling with the Drawbar is much safer, at least IMHO. Best wishes.
/ Stump Pulling with 3-Point - Any concerns? #6
I can do 3 inch trees reliably with my 30 hp machine and a chain. 4 inches I often have to wiggle a bit. 5 and up require digging.
Thanks for the replies, I have removed several trees using the both the drawbar and FEL. I stopped trying the FEL as it seems to cause to much wear and tear on the tractor due to "racking" caused by anything but a square lift attempt. The hook and pull method using the draw-bar works great as long as you have good access to the tree stump. This also prevents the tree branches from whacking you in the head :). None of these trees are over 12' tall and not a safety concern, think large xmas trees. The stumps currently giving me issue are on the side of the pond bank and I would prefer a controlled extraction by lifting up as I do not have clear access for the typical draw-bar approach. I guess my basic question is can I damage my 3-pt if I exceed the 2200lbs lift rating or by repetitive lifting?
/ Stump Pulling with 3-Point - Any concerns? #8
You should not be able to damage your three-point. It will by-pass through the pressure relief if you try to lift too much. Just be aware that when oil bypasses, it creates a bunch of heat. Not normally a problem as it is just momentary and you probably have 10 gallons of oil. But if you put a rig into a situation where you are up against the bypass for some time, that can eventually damage things. That is hard to do with normal use. Generally that happens when someone leaves a remote valve in a detent where it is flowing oil against a disconnected quick coupler....that sort of thing. That is a long winded way of saying it should not hurt your tractor. Just keep the shiny side up.
/ Stump Pulling with 3-Point - Any concerns? #9
You could use Paul Bunyan's hammer.
or a slightly more mechanized version.
Bruce
/ Stump Pulling with 3-Point - Any concerns? #10
I have pulled many things in the method you describe.
There isnt much risk in damaging the 3PH, but there is a flip-over risk as others describe.
IF you are even asking about doing this, tells me you lack experience in doing it, and I would side with others that say dont attempt it, find another way.
/ Stump Pulling with 3-Point - Any concerns? #11
Try leaning a truck or auto wheel (rim) against the tree and wrapping the chain around it:
This will give you the vertical force component that you're looking for.
If the tap root is reall strong it still may no be enough.
/ Stump Pulling with 3-Point - Any concerns? #12
LD1, that's an interesting response. How is one to gain that experience? Wouldn't it suffice to explain the risks and to suggest an abundance of caution?
I am a tractor newbie myself but I didn't spend $30K to not use the thing. I'm just sayin ...
/ Stump Pulling with 3-Point - Any concerns? #13
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=339593"/>
What brand tractor is that? :laughing:
/ Stump Pulling with 3-Point - Any concerns? #14
Many years a go I read a suggestion on pulling on something like a stump with a tractor to use long chains from the rear all the way under the tractor and attach to the front end. This way all force is down and safer than drawbar or rear end pull. I tried it once with a couple of small fruit trees and our old ferguson and it does feel more stable. As others have noted it is surprising the root strength of even some small trees.
/ Stump Pulling with 3-Point - Any concerns? #15
if you have a set of pallet forks, they make great little diggers.
you could go around to the trees and stick the forks down under the
stump a bit to start loosening them, and see if you can get anything
to move with them first. once you get them a little loose i bet they'd pull
right out with the chain.
/ Stump Pulling with 3-Point - Any concerns? #16
You may be successful at this. Not dangerous if you dont move forward, nor harmful if you dont continue to pull up while in relief bypass. If you were to move with a given sub max lift the position contriol valve will be "centered", locking that lift point. A lateral pull from there forward is very dangerous. The tractor will rear up right now. A lateral pull by backing would allow much more force before rearing. ... Safer, more extraction force - but could be harmful. May even be enuf to break the lift mechanism internally if stump doesnt give.
larry
/ Stump Pulling with 3-Point - Any concerns? #17
This concept works except the rim is usually too narrow and either turns over or buries in the ground. A large section of tree about 24" or more inches long x 20+" in diameter works better and if you have an FEL it can be moved easily into place.
I have pulled small trees using a 3 PH drawbar with larger tractors by just backing up and wrapping a chain around the sapling and raising the lift. NO danger of turning over even if the front end comes up. Lifting AND driving forward does make for a very dangerous situation. If you do that, don't raise the lift arms more than about 18" above ground (about same height as your fixed drawbar) and you should be ok since anytime the front raises enough to lower the 3 PH it would be pulling the rear wheel up also and reduce traction.
/ Stump Pulling with 3-Point - Any concerns? #18
Lift arms pivot ~ rear axle location, and the ends can rise in relation. Virtually no developing resistance to back tip in a pull.
larry
/ Stump Pulling with 3-Point - Any concerns? #19
Wrap the tree with a v belt and hook chain into that. Hook the chain to the drawbar and you are good to go.This will keep the chain from riding up the trunk of the tree. The drawbar is under the center of gravity of your tractor. As long as the location is below the rear axle, you should be fine. You will have better luck with a series of sharp tugs until you break the roots free.
/ Stump Pulling with 3-Point - Any concerns? #20
The concern about a full flip over when pulling from your 3 point stems from the elevation your chain is connected at the rear of the tractor. If your chain is lower than the rear axle, the tractor front is pushed down when pulling. If the 3 point is raised higher than the axle, the tractor front is LIFTED when pulling and if you have solid traction, your tractor rear tires keep going and the front flips over backwards.
If you have trouble imaging this, think about hooking a chain to the top of your ROPS or cab. Then hook the other end to a solid immovable object and imagine driving forward with good traction. Your front will raise up, putting even more weight on your rear wheels giving them more traction.. Say you are in full throttle decreasing your reaction ability, your rear tires keep going but the top of your ROPS (or cab) stays still. So the tractor flips over backwards in a heartbeat. It literally is that fast.
I believe the OP was talking about lifting with the 3 point and the tractor front can raise up in that case. Once the 3 point is above the axle combined with going forward is a sure way to flip a tractor backwards on top of the operator.
http://www.youtube.com/watch?v=SKlCtZttqtg&feature=youtube_gdata_player
This tractor pull event had horrible officials that obviously didn't know the basics of this problem.
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
Honda EM6500SX Generator (A62613)
Honda EM6500SX...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
