String trimmer time
   / String trimmer time
I don't deny that Sthil makes some good ones, but they are not all reliable. I have spent over $500 and got two crappy units. I just don't see what they have done to have me chose another.
   / String trimmer time #12
If you've had bad luck with them, I can certainly understand looking for another brand, and wouldn't blame you at all. I've had good luck with them. Besides the current string trimmer, I had another one I bought in 1995, never a problem with it, but sold it to my brother when I bought a DR wheeled string trimmer/mower. And that brother had a Stihl chainsaw that saw a lot of heavy duty use in clearing a place to build his house.
I do use Stihl's Ultra 2-cycle oil; more expensive, but I don't use enough now to worry about it, and I do use Stabil in the gas and don't worry about using a little extra Stabil.
   / String trimmer time #13
Time to try another brand. I have an old weed eater that still runs. I find I end up using it because I can't get my Stihl started. This is the second one and neither were reliable. I have a chainsaw that is bulletproof. Husky,Echo and Shindaiwa are sold in my area. What are you guys using?
You must be south of the 43rd if you are talking grass trimming we are at
-14 degree Celsius = 6.8 degree Fahrenheit this morning in SOUTHERN Ontario.
My Stihl chainsaw was stolen (really liked that saw) so now I use a cheapy that is easy to replace. My Stihl whipper must be 12 years old and still keeps going. I put it away empty with the last fill using stable then start it in the spring using fresh gas with a 50:1 mix. Now that I have said that watch it crap out, lol.
   / String trimmer time #14
I should also mention that the ethanol in regular fuel is not good for some engines so it was recommended that I use a higher octane fuel so there would not be ethanol in the fuel. My truck and car are diesel so this is not an issue for them, I have heard that as much as 10% is added before it is posted. My trimmer does not have the flex fuel sticker, hope this helps, Good luck!
   / String trimmer time #15
If you're not happy w/ Stihl, I'd give the Shindaiwa a try. Several folks I know have Shindaiwa 2-cycle equipment (blowers,trimmers) that is serving them well.
   / String trimmer time #16
I've got Echo: weed eater; edger; leaf blower; and, an Echo chain saw.
In 5 years I've replaced 2 fuel lines and 2 primer bulbs, no other maintenance. All have the original spark plugs and air filters. I blow the filters clean with an air hose about once a year.
I love that everything is easily accessible and made for easy maintenance. All of them see hard service here in Florida.
I have given a hard look to Echo. I just keep hearing that the entry levels are a bit underpowered. I looked into it and a med. sized engine(260 I believe)straight shaft with a solid shaft and not cable was heading north of $350. That is about $50-$75 more than a Stihl or Husky.
   / String trimmer time #18
I have 2 echo string trimmers and a Stihl pole saw. The echos are very light so the wife can run them. Wish the pole saw was lighter. All start very easy. I believe the fuel is the key to keeping them starting easy. Loaned the pole saw out and wanted to furnish gas but the borrower insisted he had gas. The saw came back set for a week and wouldn't start. The carbuerator was gummed up with some kind of oily gunk. Cleaned everthing and hasn't given a problem since. I now insist anyone using my stuff also uses my fuel/mix.
   / String trimmer time #19
We have several Echos at work that seem to run pretty well. We have so much weedeating to do during the summer that I'm often running one for eight hours a day for a week long...stopping only to fill the gas tank and put cord on the reel and for lunch.
   / String trimmer time #20
I bought a new Stihl saw a couple of months ago. While looking I asked the dealer about a new string trimmer as my old Weed Eater brand trimmer is on its last leg. The dealer recommended a Kawasaki. This dealer carries Husky, Stihl, and Kawasaki. I will likely be seriously looking this summer to decide what best fits my needs.
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
UNUSED MOWER KING SSEFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
2012 RAM 5500 (A52472)
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
