String trimmer time
   / String trimmer time #1
MESSMAKER
Bluegrass,KY
DK4710SE
Time to try another brand. I have an old weed eater that still runs. I find I end up using it because I can't get my Stihl started. This is the second one and neither were reliable. I have a chainsaw that is bulletproof. Husky,Echo and Shindaiwa are sold in my area. What are you guys using?
   / String trimmer time #2
My "Echo" is still going strong after 3 years of use and starts easy after sitting for months. Friend gave me a "Homelight" that he gave up on. Haven't played with it yet, not sure if it was him or the machine.
   / String trimmer time #3
Can't go wrong with Echo. I have a saw, trimmer, and blower. They always work.
   / String trimmer time #4
I have an Echo that is over 10 years old and still works fine. I wanted another before the EPA completely screws them up. Did some research and read a lot of good things about the Husky 326LS. They are last years model but I found some on ebay, brand new with full factory warranty, for $292 shipped, needless to say one is on the way.
   / String trimmer time #5
I have been using a Shindaiwa for about 3 years now. It has been a good machine. It is a little harder to start than I would have thought but not bad.
   / String trimmer time #6
My Stihl FS 55 will be 6 years old day after tomorrow. After the first year, I changed the spark plug, but decided that really did not need to be done, so I haven't done it since. I did my first string trimming and edging of the year with it 3 days ago and even though the spark plug is 5 years old, it started just as easily as ever.
   / String trimmer time #7
Are you putting a gas preservative in your fuel? I've found that my chainsaw problems really dropped when I started keeping Stabil in all my gas fuel.
   / String trimmer time #8
I've always had Stihl products, string trimmers, blowers, and pruners. I use them commercially. Good local dealer about 10 miles away.
   / String trimmer time #9
I've been using Stabil's brand of ethenol gas treatment. I use it everytime I fill up a 5 gal. can. Don't know about other brands but the Stihl oil you mix with the gas has fuel stabilizers in it.
   / String trimmer time #10
I've got a Stihl model that runs interchangeable attachments, though I've only got the string trimmer and a brush cutter head. It's about 5 years old and is a dream to start. I also have a small Dolmar string trimmer that's about 10 years old, and though it's too small and underpowered for anything but light use, it's been a good, reliable machine. It replaced a Ryobi string trimmer that never seemed to start well, or run well.
You'll probably hear this over and over, but always use fresh gas, and keep a few fuel filters for all your small engines on hand. The ethanol that is now in gasoline attracts water and sinks to the bottom of fuel containers. The water/ethanol will also collect in the fuel filter, so replacing them will help immensely. I use the Marine-grade Stabil (ethanol formula), and I shake up my (gas) can before filling my string trimmer, chainsaw, etc. I'm also a believer in using name-brand --Stihl, Echo, whatever-- 2-cycle oil, and not a bargain brand. Of course, don't use last season's fuel. You can mix it in small amounts into your vehicle's tank to get rid of it.
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2013 Ford F-150 (A50323)
2013 Ford F-150...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
UNUSED AGT SKID STEER QUICK ATTACH SEEDERDRILL (A51244)
UNUSED AGT SKID...
