String trimmer time
   / String trimmer time #1
MESSMAKER
Bluegrass,KY
DK4710SE
Time to try another brand. I have an old weed eater that still runs. I find I end up using it because I can't get my Stihl started. This is the second one and neither were reliable. I have a chainsaw that is bulletproof. Husky,Echo and Shindaiwa are sold in my area. What are you guys using?
   / String trimmer time #2
My "Echo" is still going strong after 3 years of use and starts easy after sitting for months. Friend gave me a "Homelight" that he gave up on. Haven't played with it yet, not sure if it was him or the machine.
   / String trimmer time #3
Can't go wrong with Echo. I have a saw, trimmer, and blower. They always work.
   / String trimmer time #4
I have an Echo that is over 10 years old and still works fine. I wanted another before the EPA completely screws them up. Did some research and read a lot of good things about the Husky 326LS. They are last years model but I found some on ebay, brand new with full factory warranty, for $292 shipped, needless to say one is on the way.
   / String trimmer time #5
I have been using a Shindaiwa for about 3 years now. It has been a good machine. It is a little harder to start than I would have thought but not bad.
   / String trimmer time #6
My Stihl FS 55 will be 6 years old day after tomorrow. After the first year, I changed the spark plug, but decided that really did not need to be done, so I haven't done it since. I did my first string trimming and edging of the year with it 3 days ago and even though the spark plug is 5 years old, it started just as easily as ever.
   / String trimmer time #7
Are you putting a gas preservative in your fuel? I've found that my chainsaw problems really dropped when I started keeping Stabil in all my gas fuel.
   / String trimmer time #8
I've always had Stihl products, string trimmers, blowers, and pruners. I use them commercially. Good local dealer about 10 miles away.
   / String trimmer time #9
I've been using Stabil's brand of ethenol gas treatment. I use it everytime I fill up a 5 gal. can. Don't know about other brands but the Stihl oil you mix with the gas has fuel stabilizers in it.
   / String trimmer time #10
I've got a Stihl model that runs interchangeable attachments, though I've only got the string trimmer and a brush cutter head. It's about 5 years old and is a dream to start. I also have a small Dolmar string trimmer that's about 10 years old, and though it's too small and underpowered for anything but light use, it's been a good, reliable machine. It replaced a Ryobi string trimmer that never seemed to start well, or run well.
You'll probably hear this over and over, but always use fresh gas, and keep a few fuel filters for all your small engines on hand. The ethanol that is now in gasoline attracts water and sinks to the bottom of fuel containers. The water/ethanol will also collect in the fuel filter, so replacing them will help immensely. I use the Marine-grade Stabil (ethanol formula), and I shake up my (gas) can before filling my string trimmer, chainsaw, etc. I'm also a believer in using name-brand --Stihl, Echo, whatever-- 2-cycle oil, and not a bargain brand. Of course, don't use last season's fuel. You can mix it in small amounts into your vehicle's tank to get rid of it.
UNUSED FUTURE 14' BI-PARTING GATE (DEER SCENE) (A51244)
UNUSED FUTURE 14'...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
Unused Delta Crash...
PALLET OF SPREADER PARTS (A51244)
PALLET OF SPREADER...
CASE 6591 T/A PORTABLE POWER UNIT (A51243)
CASE 6591 T/A...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
