Storing Tires
/ Storing Tires #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
I am soon to be purchasing a set of mounted mud tires for my UTV. I will not need them in the summer as everyplace I will be is dry farm road or improved county road. I plan on storing the mud tires in a dry, dark building and installing them in the fall.
Question- What is the best way to store mounted tires/wheels to last as long as possible??
:confused3:
/ Storing Tires #2
Buy them when you need them. All tires have a date code and I will never buy a new tire that is more than 6 months old. The clock starts the day they are made and will usually start to fail after 6 years.
For that reason alone I will not transport a trailer or dive a vehicle in my business with tires older than 6 years old.
I have seen two "new" tires fail just sitting with zero miles. Both were trailer tires. One 8 ply and one 10.
Most tire shops around here will not touch a tire over 6 years old.
What does this all mean? Buy fresh tires when its time.
Chris
/ Storing Tires
Chris,
Glad you responded! You seem to have a lot of knowledge about tires and the proper care for them. I am planning on buying new 27" Essex Surefoot on steel rims for my UTV. I plan on storing them in the summer mounted up and re-install in the fall for the mud that will soon be everywhere I want to be!
Should they be stored air up? Use any type of protectant?
Thanks
/ Storing Tires #4
Have you considered putting the tires on a metal rod supported by stands on the ends? It would be a good idea to store them out of direct sunlight. Just a thought.
/ Storing Tires #7
Chris,
Thanks
Aired up and I like 303 protectant.
Chris
/ Storing Tires #8
I suggest cryogenic freezing procedure, I hear if you book early enough you might be able to get a crypt near Walt Disney's head. Coat with spray Spam, available at local Army Barracks:eek::D
/ Storing Tires #9
I was going to suggest the method I use to store good rubber boots between seasons. I'm pleased to see, after skimming the links above, my method is the approved one. Anyway, I always figured it is not only light but air that breaks down the rubber. So I clean and dry them, and store them in a closed/sealed black trash bag. I would do the same for tires. Also note you should not put any 'protectant' on them before storing.
/ Storing Tires #10
I work for the government and we store just about everything you can think of for all branches of the military. Lots of tires. Attatched is a copy of the storage procedure we have to go by and a lot of our stuff sits in the warehouses for many years before being used. Look at page 5-79 section 5-35 where it begins to dicuss storage of tires. On page 5-80 paragragh 1 it tells you the recommended storage procedures for industrial tires.
Well I tried to attach the whole manual, but the files size is too big (15MB). So I'll try and see if it lets me attach them this way.
Frontier Forks (A64126)
Frontier Forks...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Kubota Snow plow with subframe
Kubota Snow plow...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
John Deere 8320R (A64126)
John Deere 8320R...
