Storing Tires
/ Storing Tires #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
I am soon to be purchasing a set of mounted mud tires for my UTV. I will not need them in the summer as everyplace I will be is dry farm road or improved county road. I plan on storing the mud tires in a dry, dark building and installing them in the fall.
Question- What is the best way to store mounted tires/wheels to last as long as possible??
:confused3:
/ Storing Tires #2
Buy them when you need them. All tires have a date code and I will never buy a new tire that is more than 6 months old. The clock starts the day they are made and will usually start to fail after 6 years.
For that reason alone I will not transport a trailer or dive a vehicle in my business with tires older than 6 years old.
I have seen two "new" tires fail just sitting with zero miles. Both were trailer tires. One 8 ply and one 10.
Most tire shops around here will not touch a tire over 6 years old.
What does this all mean? Buy fresh tires when its time.
Chris
/ Storing Tires
Chris,
Glad you responded! You seem to have a lot of knowledge about tires and the proper care for them. I am planning on buying new 27" Essex Surefoot on steel rims for my UTV. I plan on storing them in the summer mounted up and re-install in the fall for the mud that will soon be everywhere I want to be!
Should they be stored air up? Use any type of protectant?
Thanks
/ Storing Tires #4
Have you considered putting the tires on a metal rod supported by stands on the ends? It would be a good idea to store them out of direct sunlight. Just a thought.
/ Storing Tires #7
Chris,
Thanks
Aired up and I like 303 protectant.
Chris
/ Storing Tires #8
I suggest cryogenic freezing procedure, I hear if you book early enough you might be able to get a crypt near Walt Disney's head. Coat with spray Spam, available at local Army Barracks:eek::D
/ Storing Tires #9
I was going to suggest the method I use to store good rubber boots between seasons. I'm pleased to see, after skimming the links above, my method is the approved one. Anyway, I always figured it is not only light but air that breaks down the rubber. So I clean and dry them, and store them in a closed/sealed black trash bag. I would do the same for tires. Also note you should not put any 'protectant' on them before storing.
/ Storing Tires #10
I work for the government and we store just about everything you can think of for all branches of the military. Lots of tires. Attatched is a copy of the storage procedure we have to go by and a lot of our stuff sits in the warehouses for many years before being used. Look at page 5-79 section 5-35 where it begins to dicuss storage of tires. On page 5-80 paragragh 1 it tells you the recommended storage procedures for industrial tires.
Well I tried to attach the whole manual, but the files size is too big (15MB). So I'll try and see if it lets me attach them this way.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
6' X 14' - 4 WHEEL DUMP WAGON (A64276)
6' X 14' - 4 WHEEL...
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
