Stihl Saws/Chain Compatibility
/ Stihl Saws/Chain Compatibility #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Here is my question:
I have a 11 YO MS 290 "Farm Boss" and a brand new MS 261. Can I interchange the chains between the two saws? The MS 290 has 8 teeth in the drive sprocket; whereas the MS 261 has a smaller sprocket with 7 teeth. I use 16" and 20" bars. Both "bars" have 11 spikes on the nose of the bars. The Farm Boss chains are low kickback 26 RMC 3 chains. And the MS 261 chains are 26RS "Supercut".
Thanks,
Mike
/ Stihl Saws/Chain Compatibility #2
At long as the drive link count is the same it should be fine.
/ Stihl Saws/Chain Compatibility #4
The bars should have gauge engraved on them. as in o63 or 058, etc. That determines the garoove and accompanying drive sprocket. They need to be the same. If the saws have different gauge requirements, the chains shouldn't be switched out to one another.
/ Stihl Saws/Chain Compatibility #5
The 26 described in the OP is .063 gauge .325 pitch. Both saws use the same bar mount so the bar and chains will interchange between the saws. Actually even if the gauge didn't match, as long as the bar and chain was switched as an unit they would still interchange.
/ Stihl Saws/Chain Compatibility #6
Saw chain is grouped by Gauge of the chain and pitch. The bar should match the chain gauge. The pitch has to match the drive sprocket and the bar nose sprocket if so equiped. Any chain that the matches the gauge and pitch can be used. The number of drive links determines the bar length...
The number of teeth of the drive sprocket is like the axle ratio of a vehicle. The lower the number the less torque the saw engine has to have to pull the chain... Conversely, the larger the sprocket, the faster the chain will be pulled at the same engine RPM
For the OP question... check the gauge and pitch of each chain. You can check for pitch by comparing a length of chain side by side. If the links match, the pitch is the same. If the chain guide thickness is the same, then the gauge is the same. Obviously, the chain length has to match the bar length. 16" bar to 16 loop / 20" bar to 20 inch loop
/ Stihl Saws/Chain Compatibility #7
Depends. Normally the 290 runs 3/8"-0.050" chain and the 261 runs 0.325"-0.063" chain, but you can configure either saw to run either chain by changing the bar and drive sprocket. You would have to know what is on each saw to say for sure. They can be sold in either configuration depending on how the dealer wants to do it.
/ Stihl Saws/Chain Compatibility #8
In the original post the OP listed the 290 with 26rm chain and the 261 with 26rs chain. Both are .325 pitch .063 gauge chains. The 290 is semi-chisel and the 261 is full chisel
You guys are great....and...now, if needs be, I can interchange the bars and chains.....if needs be.
Thanks,
Mike
/ Stihl Saws/Chain Compatibility #10
I'd be running the 8T 325 rim on the 261 before I would on the 290. Might buy one to try on the 261. Like 5-7 bucks for rim.
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
John Deere 755 (A64119)
John Deere 755...
2009 Honda Pilot AWD SUV (A61574)
2009 Honda Pilot...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2013 Freightliner...
