Stick welding question
/ Stick welding question #11
All the cattle guard failures I've seen are at the weld between the pipe and beams. Since the pipe only touches the beam at a point, there's a lot of leverage on the weld. I'm attempting to make something like a saddle so the pipe is held by two welds. Will see how it works first time a cement truck runs over it. :)
It seems like a very smart idea for a stronger joint.
I'm not sure how smart it was. It doubled the required welds. I stick welded for 6 hours straight. Granted, I stuck a rod 1 out of every 3 restarts and I'm not a great SMAW welder.
/ Stick welding question #13
This is why I like GMAW (MIG). Not trying to start a debate here!
/ Stick welding question #15
What kind of welding hood do you have? Yes it's expensive but I'll bet that this will keep your head cooler. They had a replacement head gear that was just 2 small fans, but they came out with this instead. CoolBelt™ - MillerWelds
If i ever make another, I'm going to get some dual shield wire.
Adams 16T Tender Body (A61307)
Adams 16T Tender...
2021 Aquasport Boat with T/A Float-On Corp Boat Trailer (A59231)
2021 Aquasport...
2007 Volvo VNL Truck Tractor (A61307)
2007 Volvo VNL...
2018 23ft. Carolina Skiff Ultra Elite Boat with 24ft. T/A Boat Trailer (A59231)
2018 23ft...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A59230)
1987 International...
2022 KUBOTA SVL75-2 SKID STEER (A62129)
2022 KUBOTA...
