Forney Model C-5BT Welder
   / Forney Model C-5BT Welder #1
ning
Elite Member
Northern California
Branson 3520h
Someone's selling a Forney Model C-5BT Welder nearby. $60.
Currently I've got an old Miller... 130? It's a 120v unit, I use it with flux core reasonably successfully. It's definitely got its limits, and won't do much to thicker metals, so I've thought of getting another welder from time to time.
I assume that I'd need to get a bottle of ... some sort of shielding gas... to use it, and then lots of practice to learn stick.
I have a 240v plug in my shop that the original occupant used for a welder.
What is this Forney welder capable of?
How would you test it?
Is it a deal at $60, about right, or run away?
   / Forney Model C-5BT Welder #2
For around $200, you can get something much more modern, that has infinite wire speed and voltage adjustment, and likely dual voltage capable. I mean for $50-60, you are risking much, but
I've got a wire machine; I can see upgrading that someday but was curious about what this forney unit would do.
You think you can spend $200 and get a good wire welder that'll go a lot thicker? I'd definitely consider that - got a link?
   / Forney Model C-5BT Welder #4
I think it was $250 for my Vevor multi process, mig/tig/stick, they call it the 270Amp 4 in 1 (they count flux and mig as separate processes...), and it's dual voltage, with the 220 and a 120v adapter.
   / Forney Model C-5BT Welder #5
View attachment 1631505View attachment 1631506
That machine is a stick welder. No gas needed. Just welding rods. It looks like it is also a high current battery charger. So it has a DC as well as AC output. If you want to learn a new process then get it, the price is right. And it will certainly weld thicker metal than a 120 volt wire feed machine. For 60 bucks I would go for it if you want to do stick welding. To test it plug the thing in, put a rod in the clamp, put the ground clamp on a piece of steel, strike an arc and weld away. Except you don't know anything about stick welding. Better ask a friend who knows how. Or get the seller to demonstrate the thing. In any case 60 bucks for a brute force welder ain't bad.
Eric
   / Forney Model C-5BT Welder #6
plug the thing in, put a rod in the clamp, put the ground clamp on a piece of steel, strike an arc and weld away. In any case 60 bucks for a brute force welder ain't bad.
That Forney is extremely heavy and welds only with AC. As Etpm said, it's a brute force machine.
I have a similar 1960's Montgomery Wards 230-AC welder. Heaviest thing I welded with it, was to put a salvaged trailer ball mount onto the back of my box blade. I think both materials were 3/8", maybe the box blade is 1/2". Running about half of the welder's claimed 230 amp capability was sufficient.
As soon as I bought a 180 amp MIG welder, I've never used the monster ever since. But the MIG welder, using .035 flux core, was at its limit sticking 3/8 material to 1/4".
You might want to buy the Forney just to play around with welding on heavy material, thicker than 1/4", if you have an application for that. That's what it's good for, heavy crude but strong farm welds.
In contrast to the elderly but indestructible Forney, there are a lot of modern welders like what Paulsharvey suggested that can do nice work. If you never weld heavy stuff then the Formey would be wasted money. But heck I would buy it just to play with it. :)
   / Forney Model C-5BT Welder #7
Anyone notice the Forney has a brazing plug? Is there a way to arc braze? That's a process I've never even heard of
   / Forney Model C-5BT Welder #9
There isn't much to go wrong with that welder, if you want to get into stick welding get that and go grab a 5 pound box of 3/32" or 1/8" 6011 welding rod (6013 is prettier but 6011 will get more penetration) and practice... Anymore I use MIG more but when I'm doing something thick I break out my buzz box. A/C is a bit fussier but will get the job done, I went through about a pound of rod working on my brothers brush hog a couple months ago on his old A/C stick welder...
   / Forney Model C-5BT Welder #10
Only thing I would caution; even minor things, like replacing ground clamp, work clamp and leeds, and your turning the $60 purchase into a $160; and all the sudden you have new machine money, in an old machine that isn't as versatile
   / Forney Model C-5BT Welder #11
Agree, that ancient Forney only makes sense if it's usable as-is. Don't spend any money on it!
My $50 in 2003 (yard sale) Wards PowrKraft 230 hasn't needed anything beyond polishing the leads where they plug in, and the recommended oiling of its fan every few years. There's nothing inside these beyond a huge simple transformer.
On thing these antiques can do, that isn't recommended for a modern electronics-based design: run a carbon-arc torch. This is a heating device for use similar to where you would use a Bernz-o-matic propane torch. Ancient forgotten technology. I have two of them. Impressive heat, and light. I haven't found a use for them however. These might be useful for heating a metal strap to bend it, or other artistic metalworking.
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
11' CONTAINER (A60432)
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
