Starting Properly
/ Starting Properly #1
Dr_No
A friend had a few questions for me, asking how to start up his lawn mowers properly. Could you give me intructions on how to properly start and run tractors in the LT, L, and 100 series?
-Dr. No
/ Starting Properly
Bump, just run-dwon on starting it.
-Dr. No
/ Starting Properly #3
I read this post a little while earlier, but didn't answer because I don't know the particular model. That said, I'm not sure what it is you want to know?
Starting the tractor? Starting the blades?
To start the tractor he needs only pull the choke, or put the throttle at the choke position, turn it until it sounds like it trys to start, then turn off the choke and turn it over again. Then run at full throttle. Start the blades at a lower throttle and then run up the speed to full throttle for cutting.
Is this a new mower? Did your friend get an owner's manual? Any information he would need on starting should be in that manual. It does amaze me sometimes that people just don't want to read their manuals!
John
/ Starting Properly #4
Well I think the manual would be a good place to find out how to start a particular mower (or anything for that matter).
I don't have a Deer but I just push the throttle up to the "run" detent and fire it up. Starts right up and then I bring it back to an idle. I let it idle for several minutes to get everything lubricated well before I put a load on it. Between that and a good maintenance program, your friend should get lots of use out of his equipment.
You bring up a good point KiotiJohn, I didn't think about the starting blades moment. However, I engage my blades at run speed because anything lower causes the engine to lug. My blades are belt driven but I imagine most riding mowers are.
/ Starting Properly
Its actually a L120 and bought from someone else, so he does not have a manual. Further instructions?
/ Starting Properly #7
The L 120 series sounds like a John Deere L110, L120 etc series lawn mower.
To start the engine, the PTO switch must be off and the clutch pedal (the left pedal) must be fully depressed. The Fuel lever should be on full choke (full forward). Then turn the key and engage the starter. If all is well the engine will start. As soon as the engine starts move the fuel lever back out of the choke position and adjust to the desired operating RPM.
After the engine warms up, subsuquent starts may or may not require the choke to be used. Cold starts always require it, or at least my L110 requires full choke, even when it's sweating bullets hot outside.
(4) METAL TAR BARRELS (A64276)
(4) METAL TAR...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
