Starting a tractor in extreme cold temperatures
/ Starting a tractor in extreme cold temperatures #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
So for two weekends in a row, I was unable to start the tractor with temperature around -35C. Had to wait for the temperature to be a 'mild' -20C for it to start.
I have a 300W heater on the cooling line and installed last weekend a battery tender. The heater is turned on for about two to three hours prior to the attempts at starting it. The tender stays 24/7.
What I do is 4 cycles of 8 seconds glow plug and try to start it. At first, because of the battery tender, it turns pretty good but fails to start. Grey smoke comes out but that's it. I do a few more cycles of the glow plugs and it still fails to start. I crank for about 5 seconds each time. After about 5 or 6 attempts, battery is having difficulty turning the engine so I stop and let the temperature warm up. At -20C, after about 3 cycles of the glow plugs, the engine fires no problem.
What's the trick to start a diesel engine in such extreme temperatures?
/ Starting a tractor in extreme cold temperatures #2
Why are you doing multiple short cycles of the glow plugs? I would recommend trying a longer glow plug cycle time unless the manufacturer specifies not to, 1 long gp cycle will be more effective then multiple short ones.
My forklift is the worst of my diesels, it's an older Nissan and requires about 20-30sec of gp min. at anything below freezing, tractors that don't havr automatic controllers usually get about 10-15 downt to single digits, longer if colder.
Sent from my SM-G715U1 using TractorByNet mobile app
I can't. The glow plug light will automatically turn off after 8 seconds, even when manually switched to the Glow position. It's a 2010 Kioti LK30.
/ Starting a tractor in extreme cold temperatures #4
I’d try running the coolant heater for a day before you plan to use the tractor.
/ Starting a tractor in extreme cold temperatures #5
"I have a 300W heater on the cooling line.....".
I don't know what you mean by having a heater in a cooling line.
The heater should be in the block to warm the coolant in the block and the walls of the cylinders. It will heat the cylinder walls and reduce the oil viscosity locally to make cranking the engine easier. It will also help start the combustion process by warming the walls of the cylinder. I would talk to the dealer's parts department and see if they have one for your tractor. Most OEM's have a block heater for this purpose and since you are up in Canada where cold weather is the norm, your tractor should have come equipped with one.
/ Starting a tractor in extreme cold temperatures #6
OP, what viscosity of engine oil are you using?
I struggled with the same problem and recently made the switch to synthetic 5w-40 to help with cold starts. It made enough of an improvement that I felt compelled to make a short video showing the differences.
Don't mean to steal the spotlight, just a thought.
With conventional 15w-40 in temps below 10*F I would have to run the block heater for a minimum of 2-3 hours before the tractor would start. By simply changing the engine oil to synthetic 5w-40 my tractor will now easily start below 0*F without being plugged in.
/ Starting a tractor in extreme cold temperatures #7
Yes, let the engine heat up and stabilize at a warmer temperature for longer. I'll preheat mine for a day before running it, and if in doubt, I just leave ot plugged in until next time. Though I hate to waste electricity, it's still less costly than replacing a starter motor!
/ Starting a tractor in extreme cold temperatures #8
Apparently your tractor sits outside ? If you can’t store it inside you might want to try covering it with a tarp to see if that might help.
Having it plugged in for a couple extra hours longer might also help.
Proper weight engine oil definitely helps in cold weather.
Make sure you are using winter blend diesel fuel.
/ Starting a tractor in extreme cold temperatures #9
If you had a 1600 watt heater then you might get away with only plugging it in for about 3 hours. With a 300 watt heater you need to leave it plugged in all day. Also wrap a well tucked in tarp around the tractor to help keep the heat in. You can get magnetic or stick on heaters that stick to the oil pan. They help too. As already mentioned a 0w40 or a 5w40 synthetic oil also makes a huge improvement. Buy a cheap temporary garage. Having the tractor inside also helps.
I run 0w40 all year round in my diesels.
/ Starting a tractor in extreme cold temperatures #10
Is the in-line heater working? They work just as well as a block heater. They may also have to be installed in a specific orientation.
Help every thing out by putting a tarp over the engine with a radiant heater underneath. That also works well.
A little diesel fuel additive might also help. Use an additive that does not contain alcohol.
/ Starting a tractor in extreme cold temperatures #11
For my International I recently replaced a burned out 1,000 Watt cooling hose heater with a 750 Watt one and found I have to leave it plugged in for at least 2 hours and more like 4 hours when it is really cold. The 1,000 Watt one I would use for a maximum of 2 hours. I use a 5W-30 oil. 300 Watts is not enough for Québec.
/ Starting a tractor in extreme cold temperatures #12
Sent you a private message....
/ Starting a tractor in extreme cold temperatures #13
Maybe a picture of your heating setup. Should not need glow plugs when plugging in. May need longer plug in time or higher wattage for shorter plug in.
Thanks all.
Being just 300W, I'll let it plugged in longer and I'll try wrapping the engine in a tarp.
The oil was changed last fall and it was just standard 10W30. I'll try synthetic next year.
/ Starting a tractor in extreme cold temperatures #15
They also make oil pan heaters that are magnetic, one of those might help. Diesels require heat and high compression to fire. When it’s that cold the heat part of the equation is missing. I’d also load test your battery to make sure it’s good.
/ Starting a tractor in extreme cold temperatures #16
Our Kubota 5240 sits in shop that is unheated. We have seen it as low as 11 below not as cold as you but run 5w40 synthetic oil always starts on first or second turn. As mentioned before synthetic might help some heater even better and the more wattage the better
/ Starting a tractor in extreme cold temperatures #18
OP,
I have no problems starting my tractor at -40 F. I have an engine block heater (NOT a radiator hose heater), a stick on pad heater on the side of the oil pan, and a stick on pad heater on the side of the hydro sump casting. I have all 3 plugged into a timer that turns on at 430am and runs until about 10am. I'm also running synthetic engine oil.
Any time after about 530 (1 hour heat time) I can go out and start it up and it's warmed up already enough to just go do work. It starts right up with only a single cycle of the glow plugs. If I need it after the heaters have been off and it's at ambient temp, it will still start on the first glow plug cycle, but I have to let it warm up before I can use it. If it's cold out (-30 F or colder) I do high idle my tractor's engine. Keeping it at 1500-1600 rpms or higher. Idling it when it's that cold outside will cause the tractor to lose heat while idling and the temp gauge will actually drop to the "cold" peg on the temp gauge.
My opinion, as one that regularly uses my tractor at temps down to -45 F, you need all of these things to have a harmonious outcome.
1. Engine block heater. I won't say that a radiator hose heater is "worthless", but it's pretty close to it. For *real* cold, it's like holding a candle under your oil pan. Sure it heats the coolant in the hose, but that coolant isn't being circulated. A block heater heats the coolant inside the engine block, which in turn warms the entire engine block casting.
2. Oil pan heater. I prefer the stick on pad heaters, the larger of the pad size area heaters. The magnet style heater, and the small pad heater don't have enough surface area to transfer heat into the oil pan as well as the large pad does.
3. Hydro sump heater. If you're running a hydrostat transmission, you need to warm up the hydro oil as well. A large pad stick on pad heater on the side of the sump casting works very well for this.
4. Synthetic engine oil. I run the same oil year round.
If you do these things, you will see a night and day difference in how easy your tractor starts, and how soon you can get it into action.
As a side note, I think there may be something wrong with your glow plugs. Possibly one or more are not working. Even when my tractor is *cold* (if I start it late in the day or long after the timer has shut off), it will still start on the first glow plug cycle. It just takes it a while to warm up enough to actually use it.
/ Starting a tractor in extreme cold temperatures #19
just as a FYI, around here we only pay 7 1/2 cents per kwh for electricity. So about 2 cents per hour to run your coolant heater.
I suspect QC not much different so I say run it more as coolant heaters are much less efficient than block heaters as 1/2 the heat if it goes towards the rad. is lost.
fresh winter fuel, tendered battery, lightest oil allowed by your engine spec's, more coolant heater time, if outside cover engine with tarp or quilt while warming up and hopefully after start your should be good to go after 1/2hr of warm-up at 1/2 throttle.
Works for me here in MB.
/ Starting a tractor in extreme cold temperatures #20
Not sure that would help. Dunno about the OP's, but my LK3054 has an aluminum (or some other non-ferrous metal) pan.
I wonder why they have an 8 second timer on the glow plugs. I let mine run for a couple :15 or so cycles in weather that cold.
