Standalone 6ft Wide 3pth Snowblower Power Source?
/ Standalone 6ft Wide 3pth Snowblower Power Source? #1
Jaynen123
Yanmar SV 08
Sorry if this has been answered before. But I will be getting a 6ft wide 3pt hitch snowblower and I wont be running it off a tractor so I need a power source for it. Seems like my best option would be some sort or air cooled engine. My question is how much power would I need?
Im thinking a 30hp gas engine would be enough. If I go diesel does it still need to be 30hp or can it be 25hp because the torque comes in at lower rpm?
Speaking of rpm does the blower require 540 rpm? If my gas engine has peak torque at 3600rpm does that mean i will need to reduce the rpm from the engine with some sort of gear box?
Any information would be a great help.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #2
I've seen pictures of self powered blowers on the net, but they are all commercial units and mostly diesel powered.
You can build anything so long as you have the mechaical capability and the fabrication tools. Rule of thumb for any powered implement, PTO driven or self powered is 5 horsepower per foot of width. Far as diesel or gas is concerned, torque rise on a blower is important when the blower is really working hard in deep snow and diesel will give you that whereas a gas motor won't. The issue is, a diesel engine will be expensive compared to a gas motor and both will require some sort of a transmission to drive the blower as well and a diesel in cold weater will have starting issues unless equipped with a proper cold weather starting package.
Most all that I've seen pictures of are front mount, not rear mount and most are a lot larger than the width you are contemplating. You could probably find a used front mount self powered unit for sale on a tractor site like Tractor House but then you most likely will have issues because used units on municipal use will be run hard and not maintained properly.
Of course anything is possible, it all depends on the depth of your wallet and mechanical ability.
I will say that I own a 72" Lucknow rear mount that I use very infrequently and it's a power hungry implement. My tractors make 90 pto horses and when the Lucknow encounters a drift or deep snow, it can make my tractor grunt.
Good luck.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #3
Out of curiosity, why do you want to re-invent the wheel ? Are you bored and just looking to take a huge risk on spending a lot of time and money on a project that may, or may not work satisfactorily ?
/ Standalone 6ft Wide 3pth Snowblower Power Source? #4
I ran a 6 foot blower behind a 25 pto HP diesel tractor for many years. Yes, you can bury a much larger tractor using an even smaller blower - it all comes down to speed, cutting width, and snow consistency.
There are fabricators out there that enjoy projects such as what you are considering, but it would not be for the faint of heart.
Maybe take a look at some of the commercially available front mount / loader mount units and see what engines they use.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #5
Understanding to what you plan to mount this blower might help with the responses. I can't imagine you're mounting handlebars and lawnmower wheels on the thing to push it up and down the driveway. Even Jeeps and pickup trucks often have PTO-optioned transfer cases, if you plan to mount this thing to an on-road vehicle. I remember we had one on an old Dodge Ram Charger many years ago, and I've seen many more on 4wd pickup trucks. Might be easier to drive it off that, if an on-road vehicle is indeed your intent.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #6
HP required depends on several factors like snow type, snow depth, desired minimum speed of travel
Yes you need to keep the input speed in the 540 - 600 RPM range
What are you mounting this on?
How will you control chute rotation and discharge chute deflector angle?
Engine start and throttle control: Will this be remote or manual by standing next to blower?
What type of engagement clutch will you use to engage blower after engine starts or disengage with engine running?
/ Standalone 6ft Wide 3pth Snowblower Power Source? #7
You'll also want a clutch or some way to disengage the motor from spinning the blower.
This could become a bigger (successful) project than I think you know.
Like many others have mentioned, there's many variables for you power requirements...
Snow consistency
Depth
Rate of travel.
Someone mentioned 5hp/ft, I would start by doubling that. It's not a practical approach, but there's no such thing as having an over powered snow blower.👍
/ Standalone 6ft Wide 3pth Snowblower Power Source? #8
If you are only blowing light, fluffy snow, and no more than a few inches, 30hp is probably OK. But in deeper snow, or wet snow. my former 6' snow blower consumed every drop of my tractor's 50hp PTO. And that was going slow. If you ever expect conditions like that, then I would go for 50hp as a minimum. I'm sure you don't want to be repowering in a year or two, so use enough to get it right the first time.
I'd love to hear more about the project that this fits into.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #9
His tractor is listed as a mini-X. If true, no PTO.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #10
Seems it'd be a hell of a lot easier, cheaper, and more convenient to pick up an old Jeep and mount a snow plow to that, or even one fitted with one of the common Spicer PTO's, to drive a snowblower.
One real common personal plow vehicle around here was the Jeep Comanche. I had more than one friend who kept one of those for the primary purpose of pushing a 6 ft. plow up and down their own driveway. Shame they rusted too quickly, though.
Thanks for all the reply guys. I dont want to say whats its going to be on just yet. But its not a vehicle or tractor or anything ive seen before for that matter.
There was a mention of blowers that come with a diesel engine already. What are some manufacturers? I would really prefer to buy something rather than fabricate all of this.
It will be primarily used for snow left behind in a driveway from a city plow. So it sounds like 50hp or around that is what I will want.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #12
Hmm, that would pretty much make it a stationary snowblower.
Unless it's towable and you've never seen a trailer before.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #13
This size is what you mostly see. A serious and expensive unit that takes the same to push it around and a township or airport type of application.
On the opposite side of the the spectrum would be something for a side by side ATV or quad and gasoline powered but affordable.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #14
Gee, we see SnoGoes operating here each year. Just following
/ Standalone 6ft Wide 3pth Snowblower Power Source? #15
Depending on the amount and type of packed snow you are likely to need ice breakers/clod busters and considerable hp for the width.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #16
Why wouldn't you just buy a 30" or so, gas, self propelled blower? Then and do a few passes? Seems the simplest answer to your question to me?
That being said if it's wet dense snow a consumer blower, ( or even a PTO blower has a hard time chewing that stuff up and spitting it where you want it.
If it's for yourself and you have health/mobility or age issues, (also someone above said no PTO on your tractor). A 3PH dump bucket would do what you need, and much more cheaply. for that matter. Or fab a 3PH mount on a frame with 2 30" blowers mounted to it side by side, and you have your 5' blower, and the ability to dump the snow higher than 18" when the banks by the road build up.
You could even pair up the controls, and yank the drive chains as they would not be needed. just chute angle and direction, and throttles.
This time of year there are tons of good used in town blowers for sale for cheap, too!
/ Standalone 6ft Wide 3pth Snowblower Power Source? #17
I would suggest buying an older cheap 60hp tractor with independent pto, the separate engine idea is too complex
/ Standalone 6ft Wide 3pth Snowblower Power Source? #18
If that is the only task for this blower, find yourself a compact or subcompact tractor with a loader and bucket. Street plows leave very heavy and deep snow and blowers don't work so well on that. They work best on dry light snow. A bucket will make short work of that without strain or risk and will be helpful for many other tasks.
/ Standalone 6ft Wide 3pth Snowblower Power Source? #19
Berco has been making powered snowblowers for alot of years and has a very good reliability and quality rating by their owners.
for their current 72" blowers they use a 22hp Honda gas motor connected to a 4 blade 15" impellor.
BUYERS PREMIUM & PAYMENT TERMS (A59904)
BUYERS PREMIUM &...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
SAMSUNG REFRIGERATOR/FREEZER (A60432)
SAMSUNG...
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
