Spray arc...
/ Spray arc... #21
Here is some .035-inch 71M dual shield wire.
/ Spray arc... #22
Good Stuff. Dual Shield was the 1st wire to get spec approval to replace 7018 stick. Great out of position wire due to the fast freeze flux. A little on the smoky side for me though.
/ Spray arc... #23
Dual shield is pretty easy to run. Here's my very first try with .045 71M wire last year. Obviously not as pretty as Shield Arc's. :)
Terry
/ Spray arc... #24
I hate spray arc. Did that for a few months in a construction equipment manufacturing plant. It's fast, but it's HOT. I'd rather burn 1/8" 6010 or 7018 for 10 hours.
It has its place, but not in my operation.
/ Spray arc... #25
Flux-core wire encompasses hundreds of different types. The Dual shield type for the most part can be matched to specialty stick rods for most applications. It can have high production but so can self-shielded flux-core. Try some E70T-4 and it will lay a bead as fast as you can move your hand. I ran some 3/32" and was only around 400 amps(I think) but still went through a 50lb coil in under 2 1/2 hours. Check out the deposition rate of .120 at 600 amps, 39.5lbs/hr.!
Innershield(R) NS-3M
/ Spray arc... #26
3/32 is crazy sized wire. No thanks.
/ Spray arc... #27
In my line of work, it was very seldom we got wire smaller than 5/64-inch. If all the welds were vertical uphill we might get .068-inch wire.
That NS-3M wire is very fast!:thumbsup:
I've run some 3/32-inch wire when welding the precast concrete deck panels on container ship docks. We slapped a piece of angle iron under the rebar sticking out of the precast concrete panels. Made 4-welds on each piece of rebar.
Like this top detail.
/ Spray arc... #28
3/32 innershield is run through a hand held mig gun? must be a massive gun to hold and or water cooled. At BIW shipyard 1/16 is as big as it gets for mig gun use, .045-.052 is the gotto popular mig wire bigger wire like 1/8 is used on subarc.
/ Spray arc... #29
All we ever got on the job, was Lincoln's K-126 guns. I've run them at 450-amps for 10-hours a day.
2016 Ford Escape SUV (A59231)
2016 Ford Escape...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
HYUNDAI HLF25-5 STRAIGHT MAST FORKLIFT (A59823)
HYUNDAI HLF25-5...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
