Hobart 210 Running Aluminum without Spool Gun
   / Hobart 210 Running Aluminum without Spool Gun #21
Not 100% right. The contact tip does transfer some amperage but the liner does as well and why the liner MUST be securely clamped into the receptacle in the welder. as the wire travels thiugh the liner it gets receives amperage all along the way...
Been doing this stuff for decades.
The primary reason why tips are copper alloy is so hot spatter don't stick to the tip readily. It does to some extent as well as inside the nozzle and why I always start out spraying anti spatter coating in the nozzle as well as on the tip. I use Radnor anti spatter in a spray can myself, but some like nozzle dip, I don't and I clean both the tip as well as the nozzle regularly with MIG pliers and reapply the anti spatter after cleaning and with any nozzle or tip, they are consumables and have to be replaced after a time.
Not entirely true, while a metal liner may transfer some current to the wire, the contact tip can be the only transfer area.
We run full nylon liners on a few welders for aluminum where there is no metal contact until the contact tip, trust me, you don't want much current transfer through the liner as it can lead to arcing and failure.
   / Hobart 210 Running Aluminum without Spool Gun #23
One more thing. My neighbor is the weld expert. He occasionally borrows my spool gun. When I first ordered some aluminum wire he said to get the 4000 series wire for general purpose welding. TaDa
The 4043 is a preferred wire for most general welding on 4, 5 and 6000 series aluminum as long as it's not getting anodized or has a higher strength requirement.
5356 is another common wire for anodized, it doesn't flow as well and is typically is a little stronger/harder. It will also feed better if you don't have a spool gun or push pull, but for general welding if stick with 4043, you'll just have to be real careful how you manipulate the gun and keeping it straight.
I really prefer lincolns superglaze myself.
   / Hobart 210 Running Aluminum without Spool Gun #24
Do keep in mind that the liner itself transfers the amperage to the wire and not the tip
Don't think so.
I've run .035 5356 and 4043 wire with my Thermal Arc 181i and I used a teflon liner as the original steel one would stick every now and then. If you cut the whip apart you'll see the main power lead goes to the torch body and from there to the contact tip, any voltage/current in the liner is coming from the connection of the welding wire to the contact tube back thru the liner.
The 5356 fed better as it's a stiffer wire, you'd still get the occasional birds nest but all in all it worked pretty good. Keeping the lead as straight as possible would help a lot too as well as not tightening the crap put of the feed rolls. I'd also use the next size up contact tube with mixed results but it helped when welding fairley steady as the tip would get hot and the alum wire would gall to the inside of the tip.
One of the salesmen had said that he would cut 1/2 the side off the contact tube for about 1/2 the length so it was like a trough and wide open. Seemed to help a bit.
If you're using a smaller machine with limited 'oomph' as mine is, grinding the oxidization off the area you're welding will help with establishing the arc as you don't have to burn thru it to establish the arc. If you don't you'll find you're stubbing out a lot with burnback.
   / Hobart 210 Running Aluminum without Spool Gun #25
Neither of my Hobarts are like that at all. The liner fits into the socket on the welders and is secured with a thumb screw, there is no other means of transmitting amperage but the liner itself and the tip but the wire contacts the liner physically as it moves through it. Went out in the shop (even though it's Sunday) and pulled the tip entirely and viola, the wire was hot.
Your mileaage may differ but I know what mine is... Never used a liner with an insert in it and I've never had an issue with the wire, ever. Of course I run quality wires and we run a lot. I buy my wire by the case.
   / Hobart 210 Running Aluminum without Spool Gun #26
That is a different setup than I've ever seen for sure, learn sumpin' ne every day :) . You wouldn't think the small coiled wire would be able to carry any amount of current as it's not a heck of a lot larger than the wire you're welding with.
That is how my Hobart 210 is. Just held in by a thumb screw. Judging by how the liner/feed hose is connected, I could see how this works. I always felt like the nozzle tip was to add to the conductivity and to help feed the wire straight and prevent slag from entering the liner/gun.
I learn new things every so often on a project. Even the best sharpen their skills by doing the trade. That is how you get better.
To be honest, with all of the time I've put behind welding, I feel like I only got about a year or two of welding under my belt. Because I don't do it everyday. So I am still green at it. And I never went to school for it.
I also learned a long time ago, a grinder is no substitute for a good, clean, penetrating weld. ;)
   / Hobart 210 Running Aluminum without Spool Gun #29
The nylon liners are for aluminum, the only machine I know of off the top of my head that uses a metal liner for aluminum is Fronius (excellent machines by the way).
Yes the liner can transfer current, but try to strike an arc and you'll quickly be replacing the liner as the wire will arc off of it and cause damage.
There's a reason it's called a Contact tip!
   / Hobart 210 Running Aluminum without Spool Gun #30
I graduated welding trade school when I was 18, 51 years ago...crap, it seems a lot longer when you actually see the numbers in print LOL.
As for grinder, that and a can of paint are a weldors best friend :).
   / Hobart 210 Running Aluminum without Spool Gun #31
Here is some info from Lincoln. https://www.lincolnelectric.com/en/Products/le-na-magnumpropushgun. I thought a long time ago I purchased a special liner for my mig gun for aluminum. It was some type of plastic tubing with a brass end pc. I don't know where it is now. I purchased the Lincoln spool gun, the Magnum Pro 250 XL. I don't remember paying the price that they want now. Wow it is pricey.
I used to weld aluminum wheels for racing machines (before CNC made it easy to get wide stuff) with a transformer MIG; it was a giant PITA when the wire hung up, which was several times per wheel. It was very fast when it was working (spray arc is awesome!) but ultimately we went to TIG, which was slower at any given moment, but quicker overall. A spool gun would have helped but it was a limited job.
   / Hobart 210 Running Aluminum without Spool Gun #32
Gotcha. I'll just get the spool runner then. I've even had 0.30 flux core stuck in the spring liner under abuse.
Yeah, my 210 is the traditional transformer welder, a nice heavy suitcase as I like to call it. Stays on a cart most of the time.
Hard to make that guy overheat even doing insane things.
I'll have to get some straight Argon, was going to get that and aluminum wire when I go get it. Guess I'll add a spool gun. Good addition to my 210 anyways.
I have run aluminum in my Lincoln MIG welder. It has a Tweco gun and I ordered a Teflon Liner from my supplier and it worked well. If I remember right, I think I also changed my contact tip to 0.040" to get a little more stiffness. If you don't have a lot to do or only use it for Aluminum occasionally, this is what I would do - and the teflon liner runs steel wire flawlessly. Way cheaper than messing with a spool gun.
   / Hobart 210 Running Aluminum without Spool Gun #33
Really shouldn't run steel wire in your aluminum liner, the steel wire can be pretty dirty and leave contamination in the liner, which can cause issues later when you run aluminum.
Even on our Fronius welders that used a traditional spiral metal liner for aluminum, we would have dedicated liners for different wire materials.
   / Hobart 210 Running Aluminum without Spool Gun #34
I know, I only weld aluminum occasionally and when I bought the liner for aluminum, I ordered an extra one, so I could just leave the teflon liner in for my regular welding. I won't put the other liner in until I need to weld aluminum again, then I will switch them when I switch metals, the liner is just about as easy to switch in my Lincoln as the wire is!
   / Hobart 210 Running Aluminum without Spool Gun #35
You shouldn't have any problem running aluminum wire in your 210 machine without a spool gun. I have run 4043 aluminum wire in my Lincoln SP 125 Plus welder which is under powered compared to your machine. To run aluminum wire you will need to use a teflon of nylon liner in the whip. Do not attempt to use a steel liner. I have 2 whips, one with a teflon liner and the other with a steel liner. If I need to weld aluminum then I just change whips. Actually, I no longer do this because I bought a Miller machine that will at 300 amps with a 60% duty cycle. Anyway, the feed rolls should be used with the smooth grooves, not the knurled grooves. The whip needs to be held as straight as possible because this will reduce the friction in the liner. The feed rolls need to be adjusted so that they barely feed the wire. This will keep the wire from bird nesting. Adjust the pressure on the feed rolls so that the wire will stop feeding when the wire is prevented from moving when the wire is directed against the palm of your gloved hand. To make this adjustment loosen the drive rolls, direct the wire feeding from the gun against the palm of your hand or against a board or something similar. The wire should at first not even feed from the gun. Slowly increase the pressure of the feed rolls until the wire feeds from the gun but stops feeding when it hits the palm of your hand. This will keep the wire from bird nesting. Before welding make sure the aluminum is very clean. And just prior to welding use a stainless steel wire brush to clean the area to be welded. This cleaning will help greatly when first contact is made with the welding wire. Unless welding 5000 series aluminum use 4043 wire. 4043 wire is softer that 5356, which is too bad, but it is the proper alloy for 6000 series aluminum alloys. If you keep having problems starting an arc increase the pressure slightly on the feed rolls. Use a new contact tip when you first start welding because you are new at this. If you just can't get a good bead because the bead is not penetrating enough then pre-heat the aluminum before you start welding. Use one of those weed burner torches to get the aluminum good and hot. 400 degrees is good. After pre-heating give the aluminum a quick scrub with the stainless wire brush. Use the smallest diameter wire you can. To finalize, keep the whip as straight as possible when welding, adjust the feed rolls so that they barely feed wire, make sure the aluminum is very clean, and use the smallest diameter wire you can get away with.
Eric
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 CATERPILLAR 349FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2014 Freightliner M2 106 24FT Reefer Box Truck (A59230)
2014 Freightliner...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
