Spencer's Pole Barn Project
/ Spencer's Pole Barn Project
Re: Spencer\'s Pole Barn Project
Here is a picture showing the other side of the area I needed to clean up for the new driveway. It varied from 12 to 30 inches above the grade of the rest of the driveway. There were also 4 substantial stumps that needed to be persuaded to relocate to my stump pile.
This picture shows the first stump I relocated. You can see the flags and paint that mark where the buried cable line is. Only being able to work this stump from one side (because of the buired cable) made it much more difficult to get out. Normally I would have had this stump out in 10 to 15 minutes but this took me a good 45 or so.
This picture shows how shallow the cable is buried.
I dug up around 10 feet of this cable by hand. I wanted to get some slack in it because I will need to trench underneath it to run my new power lines to the pole barn.
My buddy who works for the power company was supposed to get me a 410 feet of wire on a spool. He gave the guys in the wire room a week to accomplish this task but they failed. I needed the wire by last Friday and they didn't have any partial spools with 410 feet or more. The largest partial spool they had was 340' which means they would have had to splice in another 70'. I objected strongly to this so my buddy put a full 1000' spool onto one of their trucks and drove it over to my place. As you can see in the picture its a pretty big spool, 1350 pounds plus the wood.
We just wrapped the cable around a clump of trees and he drove on down the driveway. We started beyond the pole barn and stopped near the transformer. We didn't have any good way to measure the wire so we just guessed (in my favor).
Here's the wire all piled up, it cant wait to get buried. I believe there is about 450' of wire there (actually 3 pieces each being 450'). There are three wires that are all wrapped around each other. Two of the wires are 350mcm and the neutral is 3/0 (all aluminum).
I went down the the lumber yard on Saturday morning to rent this Ditch Witch trencher. It is rated at 4" wide by 24" deep. I had very high hopes that this was going to be easy.
I figured I would start the trenching in the pole barn area first. I knew there wouldn't be any big roots in there because I had already dug them all out and filled it with nice clean fill sand. Because I had never operated a trencher before I wanted to start on an easy area. Unfortunately the wheels on the trencher didn't do very well in my nice clean fill sand /forums/images/graemlins/frown.gif
This section of the driveway went pretty good. Even though the driveway is just dirt and sand at least it was pretty well packed down from the traffic so the wheels could get some traction. The curve was the hardest part to do on this section. I also had another buried cable to cross, right where the shovel is in the picture. At least this was my buried cable and not my neighbors. It is my phone line that also supplies me with high speed DSL internet access.
Now it is time to start pulling the wire through the trench. Hmmm, how will I attach the wire to the tractor? Hey, look at what the guys that did the directional boring left out by my transformer. /forums/images/graemlins/grin.gif
I literally just found this laying on the ground only minutes before I needed it.
As most of you know I only have half of a roof on my pole building and a few tarps up for make shift walls. Of course I needed to mount my panel on the side of the barn that doesn't have a roof on it yet. So I made this enclosure to protect the panel from the elements. Now its not NEMA TYPE 3R rainproof but I think it will do.
By the way I am pushing to get power now instead of finishing the roof because I, and everybody around me, are tired of hearing my 7500 watt, 14 h.p. generator blaring away for hours and hours.
Here is the wire and conduit feeding the panel in the pole barn. I needed to have the conduit go at least 18" into the ground. I used 2 1/2" electrical conduit on this.
Now that I got the wire into the panel I need to cut it to the proper length. I didn't have any huge cable cutters like the pros have but I do have this.
The panels that I am using have lugs in them that will only accept 3/0 wire. The 350mcm wire that I am using is much larger than 3/0 and will help to reduce voltage drop that occurs over long distances like this. So I had to get these special fittings that crimp on the wire. In the picture you see the small end of the fitting, thats the same diameter as 3/0 wire.
Whenever you are using aluminum wire you need to put this special Electrical Joint Compound on them to keep them from corroding.
Luckily I use to do some sub contracting work for the local electrical supply house so they let me borrow these hydraulic crimpers for the weekend /forums/images/graemlins/grin.gif. It looks like a pretty expensive tool to me.
Here is the connector after it has been crimped.
You are supposed to torque down these lugs to a specific value. In my case it was 225 in-lbs.
OK, this panel is done enough for me to go and hook up to the live panel over by the transformer.
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
