Spencer's Pole Barn Project
/ Spencer's Pole Barn Project
Re: Spencer\'s Pole Barn Project
Mosey, I guess I will find out if the ground is too frozen today. I'm heading out now to dig some holes. I'll let you know tonight.
I went ahead and dug the last 4 holes that I need to complete the outer perimeter. I was only going to dig 2 but decided not to chance the ground freezing up on my and just dig all 4. After dark I broke out the laser level and turned it on its side to mark out where to cut the tails of the trusses off. That went fast and easy. I took some pictures but they are probably too dark. I'll play with them in Adobe Photoshop Elements and see if there is anything worth posting.
I'd like some input from you guys on how to tie in the rafters for the lean-to roof. The lean-to roof will be 2"x8" rafters that will have the same slope as the main trusses.
Should I notch the 2"x8"s to ride on top of the 2"x12" truss carrier and fasten them to the side of the trusses with a brace underneath that is fastened to the truss carrier?
Or should I use some type of metal bracket and just fasten them to the truss carrier?
Something else completely?
I've attached the best photo I have of the lean-to. I can go out later and take a better photo of the situation if that would help to explain things better.
/ Spencer's Pole Barn Project #144
<font color=blue>I'd like some input from you guys on how to tie in the rafters for the lean-to roof.</font color=blue>
Are there hangers you can use?
Mike, A hanger is what I meant when I asked if I should use some sort of metal bracket. I won't be going into the lumberyard until after Christmas so I was hoping to find out from you guys what you thought would be the best way before I went in there.
/ Spencer's Pole Barn Project #146
<font color=blue>Mike, A hanger is what I meant when I asked if I should use some sort of metal bracket.</font color=blue>
Oops, I missed that/w3tcompact/icons/blush.gif. Here's a link to <A target="_blank" HREF=http://www.tamlyn.com/other/joisthangers.html>Joist Hangers</A>. The skewed ones indicate they can handle an angle from 40 to 50 degrees.
/ Spencer's Pole Barn Project #147
Spencer,
I would opt for notching the 2x8 into the 2x12 with the 2x8 face nailed to the side of the rafter. You could add a 2x4 to the side of the 2x12 as a carrier for the bottom of the 2x8. You probably should rip one side of the 2x4 to match the roof angle so it fits snug to the bottom of the 2x8. This would be faster and less costly than the individual hangers.
Carl
/ Spencer's Pole Barn Project #148
Consult your building codes. I would assume hangers are your only legal way to attach those rafters. If you notched the 2x8 enough to fit on top of the 2x12, only 4" will be left, it WILL split. Cut a 4/12 angle on the end of your rafter, hold it up to the 2x12 header at the proper height and backnail thru the 2x12 into the end of the 2x8. After this, put a hanger under the 2x8 and nail as required. If you put the hangers in first, the tops of your 2x8's will be uneven as width varies >1/4".
Will you be placing collar-ties from the barn wall to the lean-to wall to hold it in place? A 2x6 nailed to the barn @ the elevation of the lean-to wall and going out to the header of the lean-to will work. We use them every 4'.
/ Spencer's Pole Barn Project #149
Spence,
I'll get you some pics of mine this week. I did mine completely according to the specs. so it should work where you are.
/ Spencer's Pole Barn Project #150
Hi Spence,
I don’t know exactly what tools you have on-site, but if you have an air compressor and a 3/8” air ratchet… use this to join the lean-to roof joists to your truss eave ends with lag bolts… sort of like cantilevering joists except you don’t need such a large overlap… perhaps 12-18” would be sufficient…
on the lean-to end… you can use hurricane steel straps to secure to top plate of the shed… and then have your joists long enough so you have another 24” overhang/eave for the shed end (gives you outside covered storage area, and disperses the water runoff away from the building even further…)
Well I got 2 of the last 4 pole set and concreted in place. I put the 2" by 12" truss carrier across the front of the building tying in those two poles. I read this website daily (when possible) and I don't think any of you are having more fun with your tractor than I am. No pictures tonight it was too dark.
CowboyDoc, I am still interested in seeing some pics of your barn if it is not too much trouble.
I went out and took a picture this morning to show the front two posts in place. Not much progress but at least I have the project rolling again. I did not really need to use the 2" by 12"s on the front or rear of the barn because they will not really be supporting any weight. I used them to strengthen the structure and in case I wanted to add another lean-to or an awning of some sort at a later date. Now I am ready to set the last truss on the front of the building.
No pictures tonight but I did make some progress on the lean-to roof. I got the 14 2" by 8" rafters in place but not finalized. I should have them all properly fastened and braced by tomorrow night. This is quite the hurdle I am getting over. Once these rafters are up I can actually start to put some sheathing on half of the roof. Even though I would love to get out there and plow some snow with my tractor I kind of hope this mild weather sticks around a while. Pic's tomorrow night for sure.
/ Spencer's Pole Barn Project #154
Real nice framing Spence...can't wait to see the final product.
<font color=blue>I would love to get out there and plow some snow with my tractor I kind of hope this mild weather sticks around a while.</font color=blue>
As much as I've enjoyed plowing the snow with the JD4710, I'd love to trade you some of the snow for nice dry weather as I have 2 seasons of firewood, bull dozed from hedgerows, that I need to cut up. Can't do it now until March when all this snow melts.
Bob
Here are today's photo's of the lean-to rafters as promised. I took these pic's at around 3:30 before it got dark.
I think my tractor is going to like it in it's new home (even if it is a lean-to and not the main barn).
I was going to originally 'marry' these rafters directly to the main trusses but I would not have been able to use joist hangers. I wanted a one foot overhang on the front and back anyway so I decided to just stagger these rafters in betweeen the main trusses.
Here you can see the joist hangers that I used. I could not take full potential of them but I will put a 2" by 8" underneath them and nail that to the main 2" by 12" truss carrier.
/ Spencer's Pole Barn Project #159
Real nice work, Spence!!!!/w3tcompact/icons/wink.gif
/ Spencer's Pole Barn Project #160
Spence,
You might want to check code on the way those rafters are tied in. When I built my barn it was code that I had to have two 2x12 headers to rest those rafters on at both ends. I couldn't use joist hangers according to code. It all depends on what your snow load is for your area.
