Spencer's Pole Barn Project
/ Spencer's Pole Barn Project #121
Re: Spencer\'s Pole Barn Project
Spencer, if you will not be getting much more done for the next couple weeks you better add a lot more braces to the trusses. Any strong wind will ruin what you have accomplished. I have seen the results when not enough bracing meets a little bit too much wind. It only takes a few more minutes to add the bracing and you will be glad by having the extra sense of security that your roof will not blow over. Remember, you can never have enough bracing.
/ Spencer's Pole Barn Project #122
And that bracing would go on where? From top of truss to the bottom of another truss 3-4 away? I assume you want to brace them so the domino effect will be canceled, or at least controlled. Being amongst those trees will be of some help in a wind, but I think you are right on about the wind "insurance" by bracing early.
/ Spencer's Pole Barn Project #123
In my opionion, I would brace it every possible way. Trees do wonderful things. Sometimes they block wind, other times they make a tornado effect so you can not tell which way the wind will come from. The tops of the trusses need to be tied together. Then make cross braces the length of the roof and if possible tie a couple down to the ground if you have long enough stock or down as far as you can on your end post. Look things over as it is hard to explain with out pictures or being right there but think how can it tip and when you see how add braces to prevent it. The more lumber that stiffens the roof together the more wind resistant the roof will be.
Robert_in_NY, thanks for the suggestion. I hope that you could just not see what bracing I have done with the pictures that I had posted. I spent over a hundred dollars on lumber that was just for bracing. I went out and took some different pictures to try and show you what I have done.
First View
Second View.
I braced from the bottom of one truss on an angle up to the top of a truss that is about nine trusses away (screwing to each truss along the way). On the same web I put another brace going from the top of the first truss down to the bottom of the ninth truss. I did this on both sides of the web so for every nine trusses there are four 2 by 4's for cross bracing.
/ Spencer's Pole Barn Project #126
That is what I was referring to. It was hard to see in the original picture and I have seen barns blow over that had all the pealings on and such but not enough bracing. I would hate to see it happen to your barn as well as anyone elses. As you know the biggest thing is to make sure the end trusses can not move. If they can't move then the others can not move either if they are attached to the ends unless your 6x6's tip
/ Spencer's Pole Barn Project #127
<font color=blue>Don't even think about any type OSB for the roof.With 24" spacing,you need a good grade 5/8" 4-5 ply,plywood</font color=blue>
Why's that? My place was built with plywood but 90% of homes in area are OSB and all trusses are 24" OC. We are in a snow zone and there is no problem with the strength of the OSB.
Kevin
/ Spencer's Pole Barn Project #128
Over time OSB sags between the trusses. Then you have a droopy looking roof. Plywood is a lot stronger then osb and is better suited for all roof work. I dispise OSB and prefer to not have to use it at all.
/ Spencer's Pole Barn Project #129
One reason OSB is used so much in new construction is its resistance to curling when exposed to rain. Plywood, when rained on repeatedly will curl severly. It (plywood) may be stronger (ever try to break a sheet of OSB?), but will not take exposure to weather and retain a flat look. Code in Mich calls for 1/2" sheathing with clips, no mention of plywood or OSB. All builders I know, including me, use OSB with no complaints from owners, or ourselves. Take a look at what is being used for floor joists and headers now. 1 3/4" OSB floor joists to span 18', and NO squeaks. Floors use 3/4" OSB with a lot more pounds per square inch load than any roof.
Use plywood if you want..either way, anything over 1/2" is just extra weight on your roof (adding to your dead load). Don't be afraid to do as professional builders do, they do it every day, some even care about and take pride in thier work.
/ Spencer's Pole Barn Project #130
Knight9,It sounds like you live in a fairly new home with newer homes in the area.Twenty years from now,take a good look at the roofs that are sheathed with 1/2" OSB on 24" spacings,and then tell me what you think.
In our area "that dog won't hunt" in a short ammount of time,you can start to see every rafter in the roof system.
/ Spencer's Pole Barn Project #131
I framed houses in the Wasatch Mountains in Northern Utah, during my undergrad days. Every builder in the valley used 1/2" OSB on 24" for the roofing. The crew I worked with had been using it for as long as they could remember and had never had any complaints.
Only caveat is to keep it dry. We would shovel snow off of the floor decking and continue building, but if it got too saturated it would swell quite a bit and we would have to quit until it dried enough to (hopefully) shrink back down to normal dimensions.
Clint
/ Spencer's Pole Barn Project #132
<font color=blue> ""until it dried enough to (hopefully) shrink back down to normal dimensions""<font color=black>
And you have made the point quite well - as it does not dry back down to normal dimensions, once it is wet. Wood has something called "hysterisis" which has something to do with never quite coming back to an original size after wetting and then dried.
As well, in climates that have high humidities, or where moisture condenses on the cold side of the roof sheathing (northern climates), the sheathing swells and also does not shrink back down.
/ Spencer's Pole Barn Project #133
Spencer,
How is the pole barn coming along?
PJ
I haven't had any time to get back on the project. I have been away on business for most of the last week. I now have to focus on my refrigeration class and getting ready for Christmas. Between Christmas and the new year I have all of my year-end book keeping to do (one of the joy's of being self-employed). When I do get back on the project I have to dig two holes and set the middle two posts on the front of the barn. After that I will set the last 32 foot truss and put all the rafters on for the lean-to. Once I get that far I will probably put the sheathing up on that side of the barn.
/ Spencer's Pole Barn Project #135
"dig two holes" Isn't the ground frozen up there?
Mosey, No I don't think that the ground is frozen yet. I'm pretty confident that I will be able to get holes into the ground until at least mid January.
/ Spencer's Pole Barn Project #137
Spencer,
IF frozen ground is a concern...
Just a thought, but if you think the place where you want to put those two posts might freeze too hard before you get there...
You could put something on the ground to help keep it from freezing too fast...mulch, straw, even a pile of snow would help.
Scoop it off later, and dig the holes easier than had you not covered the spots with something...
Just a thought... more important if it gets really cold where you are...
Bill in Pgh, PA
Macher, Thanks for the suggestion. I was just over in your area this week. I added some equipment into an existing Kentucky Fried Chicked to make it a Taco Bell also. It was over on Sproul Road in Springfield.
OOPS, I see you are in Pittsburgh. I was near Philadelpia, my mistake.
/ Spencer's Pole Barn Project #139
Spencer...
Yep...This place has the "h" on the end...
Just remembered that I forgot to mention that I planned on using your "I'm having beer because I'm afraid a soft drink might freeze" reasoning sometime, someday, somewhere.../w3tcompact/icons/grin.gif.
Now that has to be a classic! Why didn't I ever think of that one???
Bill in Pgh, PA
/ Spencer's Pole Barn Project #140
If the ground is frozen, you can do what the guy who built my barn does, (mine was built during the summer so I am taking his word on it). This builder does pole barns year round in ND.
Start a charcoal fire in the spot where you want to dig the night before. Next day, dig down as far as you can until you hit frozen ground again, do another charcoal fire until the desired depth is reached.
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
CATERPILLAR 316FL EXCAVATOR (A65053)
CATERPILLAR 316FL...
RHINO 127 - 7' OFFSET DISC HARROW (A64277)
RHINO 127 - 7'...
2004 John Deere 8320 (A63688)
2004 John Deere...
2022 EZ-GO ELITE...
