Solid bottom grapples
/ Solid bottom grapples #1
PreacherM
NW Ohio
Branson 2610h
I'm considering the purchase of a grapple bucket and looking for input on a solid bottom grapple.
Uses: primarily will be used for moving brush, logs, and split firewood.
A solid bottom seems like an advantage for me in that I can still haul my chainsaw, gas, oil, chains etc easily.
My tractor has a lift capacity of 1400lbs so lightweight and 48-52" max width. Anyone have experience with this grapple or one similar?
/ Solid bottom grapples #2
A grapple that has openings between the tines allows minor debris to fall out. I keep my landscape box on the rear as a counterweight and built a carrier on it for my chainsaw, etc.
I don't use it for woods work, but I also built a heavy wooden box insert that fits in my grapple to carry stones and cement for masonry work. You could use it to carry a chainsaw, but I'd suggest you consider building some kind of carrier to fit on whatever you plan to use as a rear counterweight.
/ Solid bottom grapples #3
While I haven't used that style, I can envision all the dirt that wouldn't fall out between the tines since it has a solid bottom. If you need more of a bucket for your applications, then this would work, but most grappling I do for brush and logs I feel works better with the more common tine style.
I'm not too concerned about allowing dirt to fall through. I'm mainly interested in being able to grab onto plies of brush, gripping logs, etc.
/ Solid bottom grapples #6
I use mine to move dirt also. Straight down - clamp up - lift & move. Even with the open tines - I loose very little.
/ Solid bottom grapples #7
/ Solid bottom grapples #11
PreacherM
You can just about bet that there will come a day that your chainsaw, gas, oil, chains etc. will get smashed. 😯
/ Solid bottom grapples #13
I can see many advantages to a "thumb" type grapple. I might have purchased one like that if I had known about them.
/ Solid bottom grapples #14
Buy whatever suits your needs best
If you are doing a lot of cleanup like clearing branches from the ground after felling trees you will probably tire of a smooth edge full bottom grapple pretty quick as you are walking around picking up branches by hand.
I've gone to a long bottom twin lid grapple and my lower tines are on 8 inch spacing. Tine spacing is small enough to hold decent sized rocks, large enough to sift dirt from wood and rocks. Twin lid works better for grabbing odd shaped or piles of logs. Makes for an excellent clean up rake. Still works as a carryall and I can even move loose stuff like wood chips.
I'm using the grapple and my forks more than my bucket these days.
/ Solid bottom grapples #15
I have had a Green's Machine Thumb for at least ten years;very usefull and a lot cheaper than a full grapple.Limited opening but have used for logs,brush ect.
Mine bolts on and is removeable if ever needed.
/ Solid bottom grapples #16
A clamshell style is superior for brush movement imo. That's what I have. I don't see utility in the other style of grapple. In fact, my fil and my uncle both liked my grapple so much, that they both bought the other style like you show, but neither of them use it. My grapple still sees use. They didn't think about the difference in style, they only bought what was locally available to them and it turns out the utility of the clamshell is far higher in my experience.
/ Solid bottom grapples #17
This is how you rake brush towards you and then roll the stationary part of the grapple forward to trap brush and logs. I can pick up big logs too.
/ Solid bottom grapples #18
Do you use your bucket for dirt work as pictured? I assume you'd just leave the grapple wide open?
If I went that route I would probably fabricate the entire assembly myself.
Yes, if I do dirt work, I leave the grapple wide open... unless I'm up against a building (which I have done). In that case, I remove the 3 pins and pull off just the grapple part. I've done this a few times... One time, I lost the middle pin and ended up getting one free from the company in Tarboro (I used to eat lunch in that town when I was working)... So I stopped by and walked though the factory to find the correct pin. I can not say enough good things about WR Long...
NOW, since I learned to weld... I would so build my own!!!
/ Solid bottom grapples #19
No offense but I do the same with my tooth bar and grapple... to the point of picking up so much brush and not being able to see where the heck I'm driving!!!
Again, any grapple is much better than no grapple!!!
/ Solid bottom grapples #20
I don't take offense, but I've used both and the clamshell is far superior for grapple functions imo. The other type excels in lifting tasks like forks. I have forks, so I don't see the need for that type of grapple.
4' FIELD CULTIVATOR (A63291)
4' FIELD...
2021 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2021 Posi Track...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
