Snow Equipment Owning/Operating Snow removal 102
/ Snow removal 102 #1
n8586m
Stanwood Mi
Kubota B2620 w/FEL
A topic that has been hashed over many times but maybe some different approached. First, this is on concrete and asphalt only, it does not apply to gravel.
In my area, mid Michigan, we typically get 100" a year so I figured a rear blade alone would get me through as we maybe get more than 8" once every other year. I took the load off to help with maneuverability around the cars. Also plowing three other driveways (for pay). I am averaging $60 to $75 per hour with loader only running in mid range @ 1800 rpm. I can go much faster but I have a cast on my left hand at this time.
So, because of global warming, we get 50" in December, an all time record. About half way through the month I realized that the rear blade was not going to handle the snow banks so on goes the loader. Then we get a 14" dump and I find that the loader pulls the snow away from the garage door better than the rear blade because I can see the door and ease up to it much easier. (The hydro drive can't be beat in a situation like this.) Also since none of the driveways are longer than 100', the loader bucket does just as good or better than the rear blade. And the loader can pile it up where the rear blade can't.
The first photo show pulling show with the loader, front edge curled down. The second shows the same thing. The third shows the pulling results. Number four shows my helpers. They watch my back to keep me safe from the rabbits, squirrels, ducks, geese, deer, ect., and they do a good job too. The fifth shows one job where it is difficult to put the snow and the sixth shows it cleaned. Seven shows my storage security, eight shows the chain bucket and the last shows the pre-heater. The tenth, out of sequence, show pushing snow with bucket edge tipped down. A work of caution here. Go very slow on concrete as you will find the expansion joints, they can cause a sudden stop.
Anyways, here are the photos for what it's worth.
Doug
/ Snow removal 102 #2
man that looks really good. awesome job. I used my back blade like you for a 6" snow around my cabin complex. it worked good even on the gravel. when it thawed a little I had a nice clean driveway . However I did have a good dumbs*** moment. Remember your comment about plowing around cars? Well...... seems as I was backing around my 2007 Suburban I kinda forgot where the front of the FEL was and 'nicked' the tailight assembly. Dang that sucked. Then as I was going into town the sheriff followed me into Bomgaars. I asked if the broken tailight was illegal. He said yes. Aroll of red tape later I was on my way. Then $150 later when the new tailight assembly was installed I didn't have o worry about 'probable cause' to be pulled over.
Moral: Where the heck are the edges to this thing ?
shared for humor purposes only cuz we have all been there.:D:D:D
/ Snow removal 102 #3
Very good job with the fel. Looks as good as if it were done with a blower. I have had enough of the snow already..... just keeps coming. Just a little over 8 feet so far this season and more on the way. Didn't see how much the storm for tomorrow is going to bring. Only enjoyment I get out of the snow is the seat time in the tractor. I have had a couple of friends call me and asked if I would trailer my tractor to their place and blow their driveway. Probably would have if I had a 14' trailer. But 400 feet of driveway not to mention the outlaws place behind us is enough.
I still think the plow driver sit down at the corner and waits for my flashing light to disappear, then he come roaring down the road just to deposit more snow at the end of the driveway. I got smart and waited for him today, and of course he waved as he raced on by......grinning ear to ear
/ Snow removal 102 #4
My asphalt drive is about 300' long. I've used a loader for snow removal for the last several years, much the same way as you have. I also keep the box-blade (minus scarifiers) on the back for added ballast.
We've gotten about 50" so far this year too...
/ Snow removal 102 #6
I pretty much do the same as you. loader and RBB has worked well and it beats the heck out of the shovel
/ Snow removal 102 #7
In Maryland, we usually get about 30 inches a year. All this talk of record snow falls all over the country and I haven't been able to plow yet this year!
It's really starting to agrevate me. Please send some of that lovely white stuff our way so I can get some precious seat time.
/ Snow removal 102 #8
1*I haven't been able to plow yet this year!
2*It's really starting to agrevate me.
3*Please send some of that lovely white stuff our way
4*so I can get some precious seat time.
1*Me neither.
2*Not me - suits me fine.
3* Don't send any here.
4*I don't want any cold seat time/that ain't KOOL !
/ Snow removal 102 #9
My 1400' drive is gravel, but I also use my loader. I tilt the front edge up 1/2" or so and leave just a little snow. After that I tilt the front of the loader down (not as much as the OP) and back drag in float position. I have to go over areas more than once, but it does a pretty good job. I am always looking for better ways.
Mark
/ Snow removal 102
The pre heater is a 30,000 btu natural gas heater. The entire garage is heated as my spouse uses it as a smoking room. So the temp is seldom below 50 F. The tractor starts pretty quick.
Nobody has seem to notice the chain box. It is a stainless steel ice bucket I got at Target fpr $13. Drilled a 3/8" hole in the bottom and bolted it to the drawbar. it holds a 30' plus a couple of shorter pieces.
Doug
/ Snow removal 102 #11
Great job with the fel, looks like a snowblower did it.
Great pictures too, We love them here at TBN.
Would someone please send some unwanted snow to Kentucky.
Its cold here, zero by morning. I don"t have a cab on my tractor,
But i have a cab on my honda rubicon , with a snow blade and heat.
I need some seat time.
/ Snow removal 102 #12
*I need some seat time.
Ya have a heated cab so go get some seat time.
It don't have to be pushing snow.
2016 YAMAHA YDREX6 ELECTRIC GOLF CART (A64280)
2016 YAMAHA YDREX6...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A61574)
1999 22ft Sea Ray...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2024 JCB 35Z (A60462)
SHORTWOOD LOG TRAILER (A64276)
SHORTWOOD LOG...
72in. Fork Extension (A61572)
72in. Fork...
