Sd1540 B 3 point problems
/ Sd1540 B 3 point problems #1
Neil1982
2008 Massey Ferguson GC2310
My 3 point will only lift when cold and at that it will lift and then drop with weight on it. I have replaced the piston O rings and the problem still persisted.
Any ideas what else it could be?
I have a loader on it and it works perfectly.
/ Sd1540 B 3 point problems #2
Did you check out your other thread posting. I provided the manuals. :)
Bet there are other o-rings in the system to check. And it may be a diverter valve being stuck too.
So I have replaced the O rings on the piston, honed the cylinder, replaced all O rings in the control valve, flushed all the hydro fluid and put a new screen in and I am still having the issue where it won’t lift. Any one have a suggestion as to what else it could be? Again front loader works perfect.
/ Sd1540 B 3 point problems #4
Old post but I’ve been having the same issue. Did you ever figure out what it was?
/ Sd1540 B 3 point problems #5
I just acquired a 1980 shibaura sd1500b, 3 point lift picks up good at first start,, but will ease back down (grader box 4ft), hotter gets the worse it gets. I am totally new to tractor, all decals and such are worn off, no book on it, I dont even iknow how or where to check hydraulic fluid, what type it takes or anything ! Need some good help ! Thanks
/ Sd1540 B 3 point problems #6
Use a universal hydraulic /transmission fluid. First thing to check is lift cylinder orings. I can supply parts & manuals.
2014 TAKEUCHI TB228 EXCAVATOR (A65053)
2014 TAKEUCHI...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2022 Sany SY35U Mini Excavator (A64553)
2022 Sany SY35U...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2022 Forest River GANS58SA 8ft. S/A Enclosed Cargo Trailer (A64557)
2022 Forest River...
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
