Sd1540 B 3 point problems
/ Sd1540 B 3 point problems #1
Neil1982
2008 Massey Ferguson GC2310
My 3 point will only lift when cold and at that it will lift and then drop with weight on it. I have replaced the piston O rings and the problem still persisted.
Any ideas what else it could be?
I have a loader on it and it works perfectly.
/ Sd1540 B 3 point problems #2
Did you check out your other thread posting. I provided the manuals. :)
Bet there are other o-rings in the system to check. And it may be a diverter valve being stuck too.
So I have replaced the O rings on the piston, honed the cylinder, replaced all O rings in the control valve, flushed all the hydro fluid and put a new screen in and I am still having the issue where it won’t lift. Any one have a suggestion as to what else it could be? Again front loader works perfect.
/ Sd1540 B 3 point problems #4
Old post but I’ve been having the same issue. Did you ever figure out what it was?
/ Sd1540 B 3 point problems #5
I just acquired a 1980 shibaura sd1500b, 3 point lift picks up good at first start,, but will ease back down (grader box 4ft), hotter gets the worse it gets. I am totally new to tractor, all decals and such are worn off, no book on it, I dont even iknow how or where to check hydraulic fluid, what type it takes or anything ! Need some good help ! Thanks
/ Sd1540 B 3 point problems #6
Use a universal hydraulic /transmission fluid. First thing to check is lift cylinder orings. I can supply parts & manuals.
(INOP) GRASSHOPPER FRONT DECK MOWER (A64278)
(INOP) GRASSHOPPER...
2021 BOBCAT E50 EXCAVATOR (A63276)
2021 BOBCAT E50...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2015 CATERPILLAR 730C OFF ROAD DUMP TRUCK (A65053)
2015 CATERPILLAR...
